14.6.0
14.6.0
General:
In this release we have improved the filename prettifier/matcher to make API results more accurate and reliable, improved the speed of a few areas, fixed video playback on some Samsung TVs, and more!
We are close to merging some work to make some media players like Samsung TVs fetch thumbnail updates. This is a commonly-reported problem we hope you will enjoy.
Click here to see all changes in this release
Download:
Support us:
chickyboom
Re: 14.6.0
Post by chickyboom »
(I don't know if this is fixed in 14.7.0)
I just installed 14.6.0 over 14.5.1, and now it no longer recognizes my Samsung TV with:
Media renderer was not recognized. Possible identifying HTTP headers:
User-Agent: DLNADOC/1.50 SEC_HHP_[TV] MyTVHere/1.0 UPnP/1.0
For now I forced a Samsung renderer that works fine,
Re: 14.6.0
There was some minor tweaks to the Samsung confs so that newer models would use a conf that is set up for 4K instead of falling back to very old one.
If you post your logs I should be able to see why this one is not working for you, just make sure to turn off the forced renderer so I can see what will be used.
chickyboom
Re: 14.6.0
Thanks much, here's the log (shortened a bit to fit). [I purposely set the default tv name and only the Samsung renderers are enabled.]
Reason: removed logs
Re: 14.6.0
Please post your full logs in the Help and Support section, follow the red section at the top on how to do them.
Don't force or disable any renderers so I can see what conf UMS would normally pick.
I'll delete what you posted as it contains no useful information.
