Unhandled exception warning "CC3"
albertatoltec
Post by albertatoltec »
This isn't a extremely large issue but I submitting should it not be known. I haven't seen any other posts that describe the same issue.
I have a number of DVD titles which I have placed in a drive visible to UMS. When starting UMS, the log becomes extremely large with the warning message associated with all of the DVD titles. It doesn't affect the ability to view the DVD files. Just wondering if anyone else is aware of the message and if there are any plans to deal with it.
I am including a text file which shows the UMS warning message along with the MediaInfo metadata regarding two of the DVD files. All of the DVD files have the metadata descriptions.
Cheers,
UMS Warning Message.txt
(8.19 KiB) Downloaded 11881 times
Re: Unhandled exception warning "CC3"
This appears to be EIA-608 closed captioning and I don't think UMS is set up to handle it properly, or this is broken.
It would be helpful if you post your logs so I can get more information on this error and what version of UMS you are using, then I'll make an issue on Github to be fixed.
albertatoltec
@mik_s,
Thanks for responding. I wasn't really concerned that it would be fixed. I was more curious to see if it was known.
Restarting UMS after Microsoft Tuesday, most of the "Unhandled exception" warnings are for "CC1". See the example below.
I looked back at the DVD files that are affected and I believe I know what has happened. It appears the original software application that I used to create the files automatically added the closed-caption component to the file. After a period of time I became proficient in using ffmpeg directly I stopped using the application and converted the video and audio. Being at the command level and not specifying text or closed captioning streams, those DVD files do not cause a warning in the UMS log file. It means I will have to manually re-encode the DVD files that caused the warnings. I should be done by 2026. :(
UMS warning message in log file.
WARN  2024-10-08 16:42:33.722 [Media Scanner] Unhandled exception while resolving 01 Pilot.mp4: For input string: "CC1"
Corresponding video file that caused the warning message
General
Complete name                            : M:\B\Bones\Season 1\01 Pilot.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/dby1/iso2/avc1/mp41)
File size                                : 3.19 GiB
Duration                                 : 44 min 3 s
Overall bit rate                         : 10.4 Mb/s
Frame rate                               : 29.970 FPS
Collection                               : Bones
Season                                   : 1
Album                                    : Bones, Season 1
Album/Performer                          : Bones
Part                                     : 1
Part/Position                            : 1
Part/Total                               : 1
Track name                               : Pilot
Track name/Position                      : 1
Track name/Total                         : 22
Performer                                : Bones
Director                                 : Greg Yaitanes
Actor                                    : Emily Deschanel / David Boreanaz / Michaela Conlin / T.J. Thyne / Eric Millegan
Screenplay by                            : Hart Hanson
Genre                                    : Drama
ContentType                              : TV Show
Description                              : Forensic anthropologist Dr. Temperence “Bones” Brennan teams up with FBI agent Seeley Booth to investigate the murder of a Senate intern, the political implications of which may prove to be staggering. / F.B.I. agent Seeley Booth teams up with forensic anthropologist Dr. Temperance “Bones” Brennan to solve some of the most baffling and bizarre crimes ever.  Booth depends on clues from the living witnesses and suspects, while Brennan gathers evidence from the dead, relying on her uncanny ability to read clues left behind in the bones of the victims.  Their different investigative styles cause the two to frequently clash, creating an undeniable chemistry and just the right touch of dark humor.
Recorded date                            : 2005-09-13
Tagged date                              : 2022-03-11 18:43:46 UTC
Writing application                      : Lavf59.9.101
Cover                                    : Yes
Part_ID                                  : 101
LongDescription                          : FBI Agent Booth needs forensic anthropologist Dr. Brennan's help to solve the case of a decomposed body found in a pond in Arlington National Cemetery. She agrees to help if she is a full partner in the case.
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 10 000 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 29.970 (29970/1000) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.161
Stream size                              : 3.05 GiB (96%)
Writing library                          : x264 core 164 r3075 66a5bc1
Encoding settings                        : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                                 : English
Color range                              : Limited
Color primaries                          : BT.601 NTSC
Transfer characteristics                 : BT.601
Matrix coefficients                      : BT.601
Menus                                    : 3
Codec configuration box                  : avcC
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : ac-3
Source duration                          : 44 min 3 s
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 141 MiB (4%)
Source stream size                       : 141 MiB (4%)
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 1
mdhd_Duration                            : 2643227
Dialog Normalization                     : -31 dB
cmixlev                                  : -4.5 dB
surmixlev                                : -6 dB
dialnorm_Average                         : -31 dB
dialnorm_Minimum                         : -31 dB
dialnorm_Maximum                         : -31 dB
Text
Format                                   : EIA-608
Muxing mode                              : SCTE 128 / DTVCC Transport
Muxing mode, more info                   : Muxed in Video #1
Start time (commands)                    : 1 s 602 ms
Start time                               : 9 s 444 ms
Stream size                              : 0.00 Byte (0%)
Count of frames before first event       : 317
Type of the first event                  : PaintOn
Menu
Format                                   : Timed Text
Codec ID                                 : text
Encoded date                             : 2022-03-11 18:43:46 UTC
Menu For                                 : 1
00:00:00.000                             : Chapter 1
albertatoltec
@mik_s,
Last night I rebuilt the video that I listed previously. This time I took the VOB file directly and used ffmpeg to create the MP4 video file. When the video file was completed, there was a "CC1" component within the metadata. The following is the MediaInfo listing of the metadata of the conversion. Should I submit this as an example of the warning message and a suggested enhancement to UMS to look into the warning?
Cheers,
General
Complete name                            : BONES_S1_D1_A\01 Pilot.mp4
Format                                   : MPEG-4
Duration                                 : 44 min 5 s
Writing application                      : Lavf61.6.100
Video
Format                                   : AVC
Codec ID                                 : avc1
Color space                              : YUV
Bit depth                                : 8 bits
Writing library                          : x264 core 164 r3192 c24e06c
Audio
Format                                   : AC-3
Codec ID                                 : ac-3
Duration                                 : 44 min 4 s
Source duration                          : 44 min 4 s
Bit rate                                 : 448 kb/s
Default                                  : Yes
Alternate group                          : 1
cmixlev                                  : -4.5 dB
surmixlev                                : -6 dB
Text
Format                                   : EIA-608
Start time                               : 9 s 310 ms
I had a look around Github for mentions of CC1 to CC4 and I think these are meant to work (was on a 300+ message thread so didn't read most of it) so there might be a bug related to this. Besides that I know little about it.
If you post your logs then I will be able to create an issue for it to be fixed, single line log messages are no good on their own.
albertatoltec
@mik_s,
I am enclosing the UMS debug file as per your request. The file show both "CC1" and "CC3" unhandled exception messages and also lists "java.lang.NumberFormatException: For input string:" messages which may be beneficial.
Cheers,
ums_dbg_2024-10-10-14-04.zip
(26.18 KiB) Downloaded 11836 times
Thanks but they were not in trace mode so it does not show the source of the error, whether it is a database issue, media info, or somewhere else.
Could you do them again while making sure trace logging mode is active?
albertatoltec
@mik_s,
Here is the trace log of the same directory.
ums_dbg_2024-10-11-06-15.zip
(174.67 KiB) Downloaded 11875 times
This turned up again here and this time it appears to be more serious as it is stopping scanning and getting a filelist while browsing a folder.
At the time I kinda dismissed this as a minor problem and assumed that file would be ignored, and the logs you made at the time showed this and you said they were still worked.
I was finally able to get a video with these closed captions and verified that it is causing the other problems.
This has just been fixed and is waiting to be merged with the main code so should be in the next release. This is the issue I made.
