[Solved] Info windows
wolfgangsaul
Post by wolfgangsaul »
if I change a value in the setup and save it, an information window appears at the bottom right. This is only visible for a very short time and I cannot read the text. Can I set the length of showing the window somewhere?
Wolfgang
Re: Info windows
I don't think there is a setting for how long the notification shows but it usually only a confirmation that for things like the settings being saved.
I'll make a suggestion if this could be configurable so it can be shown longer.
Re: Info windows
Thanks for the suggestion. In the next version, all error notifications will stay open until you close them, and all success notifications will stay open for longer - before it was 3s and now it is 8s
