64 Bit windows installer please for 14.10.
Yoji
Post by Yoji »
Trying to stay calm... but WTH is going on?
follow up from this thread I raised..
viewtopic.php?t=16375
I thought.. OK.. stay calm... cut them some slack.. wait for 14.10 when it all fixed..
So 14.10 now released to us plebs..
I go to download from web... it downloads UMS-Windows-14.10.0-x86.exe
I say to myself "Dont panic... they say it all fixed.. so may be its a dual installer and will install 64 bit or 32 bit... when it detects what I have... after all, they say it all fixed in 14.10"
But when I go to install... it says same message "there is a specific 64 bit installer... do you want to continue"... so air is blue...
I frig around on github ... and finally find the page where all downloads are and find the UMS-Windows-14.10.0-x86_64.exe
SO I assume I happy now..
But WHY is your web site downloading 32 bit by default... no option for 64 bit (even if you go for "all downloads" option)..
PLEASE can you get your act together..
Fredo1650
Re: 64 Bit windows installer please for 14.10.
Post by Fredo1650 »
Hello, yes indeed putting a 64-bit option on the download would be good because by default it is 32-bit.
An option like this if:
UMS-Windows-14.10.0-x64.exe
Or putting an automatic detection of 64 bits which downloads the correct adapted version would be even better.
At the time I am writing this post, the Download 14.10.1 button is not working (error 404)
This would have been created automatically but due to recent naming convention change and adding the x86 builds back this may have messed it up again.
I have left a message on Github that the download link is broken so should be fixed soon.
In the meantime this shoud work
https://github.com/UniversalMediaServer ... x86_64.exe
