Can't create a new user during media analysis
BitEater
Post by BitEater »
Hi all,
while UMS analysis the media files at startup, I can't create a new user, because after every file ("Getting API info..." in the status line) the focus is lost.
Is that a known issue? Can't find it.
Thank you
BitEater
Re: Can't create a new user during media analysis
Not sure what you mean. Can you post logs?
BitEater
Post by BitEater »
When I try to create a new user while UMS analyses new media (see status bar at the bottom), the focus in the Username text box gets lost with every new file and the original values for user and password a restored (data of current user?).
I don't think that log files are helpful here.
OK I think I understand what you mean. Every time the status bar changes it resets the value in the input boxes.
I don't have enough files on this new computer to do a long enough scan to test this as it is over in a second.
I'll open an issue for this on Github.
BitEater
Post by BitEater »
Thank you!
