None of my shared files show up on PS3.
Clofftai
Post by Clofftai »
Below attached is my log file. Its weird cause I can see Universal Media Server in my Video, Music and Pictures section in the XMB, but the only folder is Videos which is empty. I'm sharing 2 different folders with content inside of them that I've played on this console before.
ums_dbg_2025-06-24-16-16.zip
(76.79 KiB) Downloaded 14 times
Clofftai
Re: None of my shared files show up on PS3.
Post by Clofftai »
Tried restarting my computer, PS3, sharing different folders, all with the same result. Only folder that shows up seems to be one called "Videos" that I am not sharing.
Clofftai
Post by Clofftai »
Reinstalled UMS and deleted the database folder, but that didn't do it, so I reinstalled Windows and that seemed to fix it... :roll:
That is strange as you should not have needed to reinstall windows. It was probably a firewall rule that was blocking it.
I did see a request from the PS3 where the ObjectID was null so UMS did not know what to send back.
I don't know much about the low level communication so don't know why this would be null.
TRACE 2025-06-24 16:14:58.550 [jupnp-sync-protocol 140-1] net.pms.network.HttpServletHelper Received a request from 10.0.0.70:
============================= UPNP HTTP SERVER REQUEST BEGIN ================================
POST /dev/3d143329-64a6-4bfb-b328-dd35f38baa9b/svc/upnp-org/ContentDirectory/action HTTP/1.1
HEADER:
  X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";
  Host: 10.0.0.158:5001
  User-Agent: UPnP/1.0 DLNADOC/1.50
  Content-Length: 957
  Content-Type: text/xml; charset="utf-8"
  SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
CONTENT:
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
    <s:Body>
        <u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1">
            <ObjectID>null</ObjectID>
            <BrowseFlag>BrowseMetadata</BrowseFlag>
            <Filter>@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize,@restricted,@dlna:dlnaManaged</Filter>
            <StartingIndex>0</StartingIndex>
            <RequestedCount>1</RequestedCount>
            <SortCriteria/>
        </u:Browse>
    </s:Body>
</s:Envelope>
============================= UPNP HTTP SERVER REQUEST END ==================================
DEBUG 2025-06-24 16:14:58.550 [jupnp-sync-protocol 140-1] net.pms.store.MediaStore Bad id null found in path
