Version 3.5.0 is released
General:
This release improves the configuration wizard, program icon, filename prettifying, renderer support, shared folder control, stability, speed and more!
Changes since 3.4.2:
  • General:
    • Added a reminder at the end of the configuration wizard about optionally setting shared folders
    • Added an option to run the configuration wizard on the next program start
    • Added the ability to specify folders to ignore (folders_ignored in UMS.conf)
    • Made the program icon look better in some situations (added more resolutions)
    • Expanded filename prettifying
    • Fixed OpenSubtitles support
    • Improved stability of packing debug files
    • Improved readme file
    • Improved speed
    • Cleaned some renderer configs
    • Increased the safety of using -ac, -ab and -c:a in the CustomFFmpegOptions string in renderer configs
  • Renderers:
    • Improved support for DirecTV and Samsung phones when using FFmpeg
  • Languages:
    • Updated English
  • External Components:
    • Updated h2database to 1.3.175, which:
      • Improves stability
      • Updated Logback to 1.1.1
    • Updated MPlayer/MEncoder for Windows to SB56, which:
      • Improves DVD support
      • Fixes encoding sometimes finishing too soon
      • Improves support for the following video codecs: MPEG-1, MPEG-2, H.264, H.265, VP8, VP9
      • Improves support for the following audio codecs: DTS
      • Improves support for the following containers: Matroska, MOV, OGG
      • Adds x265 encoding support
      • Improves audio sync
      • MPEG-4 adheres more strictly to spec limits
    • Updated Netty to 3.9.0, which:
      • Improves speed
      • Fixes bugs
    • Updated slf4j to 1.7.6, which:
Upgrade Notes:
For all versions below 3.2.0:
If you have enabled FFmpeg's fontconfig or hid the New Media folder, you will need to re-apply those settings.
For all versions below 3.0.0-b1:
Re: Version 3.5.0 is released
I haven't tried it, but programs compiled and coded for Java 4, 5 and 6 still run fine with Java 7, so yes it should run with Java 8.
DeFlanko
Contact:
Post by DeFlanko »
Excelent.
Wolfgan
Post by Wolfgan »
Thanks!
Raker13
Post by Raker13 »
3.5.0 is still stripping MKV container. Selecting file opens as MPEG with no engine names in trancode folder. OPPO 93. Going back to 3.3.0 corrects everything.
cinephile
Post by cinephile »
So are the MPlayer/MEncoder improvements only for Windows or also for Mac?
Phonism
Post by Phonism »
Been running 3.5.0 since release - steady as a rock! Thank you!
UMS 5.3.0 - Java 8 update 60 - Windows 10 Pro 64bit
Intel Core i7-3770 - 8GB RAM
PS3 Slim 120GB
PS4
jorgehav
Post by jorgehav »
Cache performance in 3.5.0 is poor and hide content from folder, so I downgrade to 3.3.0.
Regards,
Jorge
Dosageko
Post by Dosageko »
Will this version re-create the database or can it use the old database from v3.4.2 (Windows Version) ?
thanks
