Web (php, perl, python whatever) renderer ?
Hello everyone !
I would like to know if such a thing as a webui render does exist, something like a "in browser" media browser and player.
Thanks, have a nice day.
Re: Web (php, perl, python whatever) renderer ?
Working on it: https://github.com/UniversalMediaServer ... r/pull/142
UPDATE: 4/19/2014
Also so its easier for all -- ill be building and updating this link whenever possible: UMS-Web-Branch.exe
UPDATE: 4/19/2014
Universal Media Server Wiki!
I read all the comments and files changed. Tons of work, thanks for all the effort to the dev team! (and tdcosta seems to be on fire looking at the latest PRs
This feature will be wonderful for incorporating playing capabilities to any device with a modern browser. Any plans to enable an Alpha test version once most of the core changes are introduced?
Thx, Wolf
Thx, Wolf
Wolfgan wrote:I read all the comments and files changed. Tons of work, thanks for all the effort to the dev team! (and tdcosta seems to be on fire looking at the latest PRs
Thx, Wolf
TdCosta should rename himself to "TDCosta_ON_FIRE"
If you go to the wiki and view the how to build documentation.. you can build that Branch right form netbeans!
it works great.
Thanks! Will surely try it.DeFlanko wrote:If you go to the wiki and view the how to build documentation.. you can build that Branch right form netbeans!
it works great.
Just to avoid having to install a netbeans environment, as I already have UMSbuilder installed and working, do anyone know if it will allow building a different branch?
I just found that the only reference to the branch is in the build scrip at:
Can anyone confirm that replacing master with web will produce a working jar?
Thx, Wolf
CALL java -jar ../jgit-cli.jar merge origin/master -s theirs
Thx, Wolf
there is... but the easiest way is to use a git app and switch branches on the Code Folder...
i think there is also in the PR someone went into details about change in the BAT file to pull from another branch.
Updated my first post to have the latest EXE for the Web Branch there.
That would be me, and here's the batch file.DeFlanko wrote:i think there is also in the PR someone went into details about change in the BAT file to pull from another branch.
Thaaaaaaaaath's right... Thank you Infidelinfidel wrote:That would be me, and here's the batch file.DeFlanko wrote:i think there is also in the PR someone went into details about change in the BAT file to pull from another branch.
Excellent, thanks guys!
