Version 3.6.2 is released
General:
This release improves support for wireless connections and many renderers, fixes lots of bugs and more!
Changes since 3.6.1:
  • General:
    • Tweaked the default Wi-Fi settings for smoother playback on slower networks
    • Fixed automatic updating on Windows
    • Fixed a memory leak
    • Fixed several bugs on OS X
    • Optimized code
    • Improved logging
  • Renderers:
    • Improved support for Apple mobile devices (iPad, iPhone, iPod)
    • Improved support for DirecTV HR
    • Improved support for LG LA644V Smart TV
    • Improved support for Nokia N900
    • Improved support for Pioneer Kuro
    • Improved support for Samsung mobile devices
    • Improved support for Sony Bravia 4500
    • Improved support for Sony Bravia EX620
    • Improved support for Telstra T-Box
  • Languages:
    • Updated Spanish translation (thanks, AlfredoRamos!)
Upgrade Notes:
For all versions below 3.2.0:
If you have enabled FFmpeg's fontconfig or hid the New Media folder, you will need to re-apply those settings.
For all versions below 3.0.0-b1:
Madoka
Re: Version 3.6.2 is released
Post by Madoka »
Thanks for the new release!!
Wolfgan
Post by Wolfgan »
Thanks a lot!
burritolnx
Post by burritolnx »
Your awork is awesome, thank a lot!!!
Uppie
Post by Uppie »
works like a charm on the iPAD now (Free AcePlayer with the AC3-fix installed). With DTS-tracks there is audio drop-out but with AC3-tracks it's really OK. I use MEncoder as an engine to get subtitles
Thanx for all the magic!
Uppie
nenito2k
Post by nenito2k »
@subjunk
Amazing work for all these years ! UMS is fantastic...but for renderers do we really need all those useless TV's ? Mede8er should be on your top list as it is the most used media player...plus i could not get it to work for HEVC transcoding.... :(
keep it up !
Kefran
Post by Kefran »
Hey guys, will there be a Java7 download for OSX soon? I've checked SourceForge, however the latest Java7 is for 3.6.1?
Thanks for all your efforts! :D
Madoka
Post by Madoka »
Oh, the "Make single instance configurable" option for 3.6.3 sounds great!! Can't wait to try it.
Optimus_prime
Post by Optimus_prime »
Kefran, Sorry i've been slow but it should be up tomorrow :D
Kefran
Post by Kefran »
Thanks Optimus.
