stream movie to DLNA client not support format
christophe195
Post by christophe195 »
i want to send a movie to a DLNA client but it wont play. After a search i have found that that format not working on my client. Can i set UMS so it convert to the right format wen it stream's the movie?
Working video format's
  • MPEG_PS_NTSC
    MPEG_PS_PAL
    MPEG_TS_SD_NA
    MPEG_TS_SD_NA_ISO
    MPEG_TS_SD_NA_T
    MPEG_TS_HD_NA_T
    MPEG_TS_HD_NA_ISO
    MPEG_TS_HD_NA
    MPEG_TS_SD_KO
    MPEG_TS_SD_KO_T
    MPEG_TS_SD_KO_ISO
    MPEG_TS_HD_KO
    MPEG_TS_HD_KO_T
    MPEG_TS_HD_KO_ISO
    MPEG_TS_SD_EU
    MPEG_TS_SD_EU_ISO
    MPEG_TS_SD_EU_T
    AVC_MP4_BL_CIF15_AAC_520
    AVC/H.264
    MPEG-4 Part2
    MPEG-1
    XVID
Tanks.
valib
Re: stream movie to DLNA client not support format
Post by valib »
christophe195
I have tried multiple renders. The panasonic TV works, i have video and sub but no audio.
How can i fix that? i down't now what the client support.
valib
Post by valib »
Please again follow the How to ask for support. We need more information to help you eg. what is your renderer, setting etc.
christophe195
sorry this is new for me. do you mean this:
this is the file from my self edit render, i have video and subtitle but no audio:
RendererName=my box
UserAgentAdditionalHeader=
UserAgentAdditionalHeaderSearch=
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeVideo=MPEGTSAC3
TranscodeAudio=asf
DefaultVBVBufSize=true
MuxH264ToMpegTS=false
MuxDTSToMpeg=false
WrapDTSIntoPCM=false
MuxLPCMToMpeg=false
MaxVideoBitrateMbps=0
MaxVideoWidth=0
MaxVideoHeight=0
H264Level41Limited=true
#MimeTypesChanges=
DLNALocalizationRequired=true
#TranscodeExtensions=
#StreamExtensions=
MediaParserV2_ThumbnailGeneration=false
ForceJPGThumbnails=true
ChunkedTransfer=true
TextWrap = width:52 indent:10 height:3 whitespace:9 date:0
MediaInfo=true
# Supported audio formats:
Supported = f:wma    n:2   m:audio/mpeg
Supported = f:mp3    n:2   m:audio/mpeg
Supported = f:lpcm   n:2   m:audio/L16   s:48000
# Supported image formats:
Supported = f:jpg   m:image/jpeg
# Supported video formats:
Supported = f:mpegps|mpegts   v:mpeg1|mpeg2     a:ac3|dts|lpcm|mpa|mp3                    m:video/mpeg
Supported = f:mpegts          v:h264|vc1        a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/vnd.dlna.mpeg-tts
Supported = f:mp4|m4v         v:mp4|h264        a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/mpeg
Supported = f:avi|divx        v:divx|mp4        a:ac3|lpcm|mpa|mp3                        m:video/mpeg
Supported = f:mkv             v:mp4|divx|h264   a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/vnd.dlna.mpeg-tts
this code give me audio and video but no subtitle. How can i make it work?
# Profile for Telstra T-Box.
RendererName=Telstra T-Box
UserAgentSearch=telstra
Video=true
Audio=true
Image=true
SeekByTime=false
MediaInfo=false
TranscodeVideo=WMV
TranscodeAudio=asf
WrapDTSIntoPCM = true
MaxVideoBitrateMbps = 0
MaxVideoHeight = 1080
MaxVideoWidth = 1920
H264Level41Limited = true
TranscodeAudioTo441kHz = true
TranscodeExtensions=wmv,asf
StreamExtensions=mkv,avi,mp4,mov,mpg,mpeg,mpegts,mpegps,mov
TranscodeFastStart=true
ForceJPGThumbnails = false
valib
Post by valib »
Have you read the instructions how to create custom renderer.conf carefully? In your code i smissing UserAgentSearch =
"your renderer search string"
which is vital or is your renderer Telstra? We can help you but without information from your debug.log it is almost impossible so please do exactly what is written here viewtopic.php?f=9&t=556
christophe195
Is this the file you need?
i have set it up that if the render is not fout ums gets my render .conf file.
(17.72 KiB) Downloaded 501 times
valib
Post by valib »
Your UserAgent is
User-Agent: L21XTLN/v4.11-rc-368-g5ae72c6 UPnP/1.0 BH-upnpcp/2.0 DLNADOC/1.50
so add the following code
UserAgentSearch = L21XTLN
to your renderer.conf and UMS should recognize it. Also delete
TranscodeVideo=WMV
TranscodeAudio=asf
and hopefully audio will work because your renderer doesn't support asf format. Explanation what this setting for audio does you can find in PS3.conf
christophe195
sorry but i have still no sound, detection works.
RendererName=Telenet Digicorder
Video=true
Audio=true
Image=true
SeekByTime=false
MuxDTSToMpeg=false
MuxLPCMToMpeg=false
MaxVideoWidth=0
MaxVideoHeight=0
MediaInfo=true
VLC codex info from one of my mp4 files, that give no audio
The client is a telenet digicorder, it is from the be distribution company so manny have this client. mayby it can be add to ums?
http://klantenservice.telenet.be/conten ... op-mijn-tv (dutch)
valib
Post by valib »
christophe195 wrote:sorry but i have still no sound, detection works.
Does it mean that you have no sound at all or only for some videos like in your example? Please be more accurate in your answers. Set the debug to trace and try to play some videos which don't work and upload the log.
