Empty List while browsing with Medion X85008 (MD 86250)
I try to use UMS with my new Medion X85008 (MD 86250).
The Server is detected fine and I'm able to browser the (virtual) filesystem. But upon entering a directory with .mp3 Files it gives me the Message <empty> and jumps back.
The UMS is configured corectly - I can access it and play with another DMR. The User Agent used by the Medion DMR ist "FSL DLNADOC/1.50 UPnP Stack/1.0"
I tried creating my own renderer.conf file but without luck.
I will attach a debug.log with level trace . I hope you can help me or point me to the right direction.
Regards
Stefan
Regards
Stefan
debug.log
- (45.71 KiB) Downloaded 739 times
Re: Empty List while browsing with Medion X85008 (MD 86250)
Here is the descriptive XML File from the DMR. I don't know if this helps but it's the best I can provide ...
Regards
Stefan
Regards
Stefan
Medion.xml
- (2.5 KiB) Downloaded 886 times
Hi again,
is there anything else I could provide to help debugging this problem. I really like to use UMS - it's the fastest and feature rich solution I came across.
Stefan
Stefan
Still no luck here ,
any advice ?
any advice ?
Hi hagie, does it mention anything in the product manual about the supported formats? I can't find a manual for it online
It should be MP3, WMA and FLAC.
Regards,
Jens
Jens
