[Solved] External subs worked on 4.0.3 but don't on 4.1.0
I noticed yesterday that some videos with external subtitles that used to work fine with UMS 4.0.3 now don't work with 4.1.0.
I thought maybe I had messed something up, because I had been fiddling with some settings, so I've uninstalled UMS, deleted the ProgramData/UMS folder and installed it again.
I've tried 3.6.2, 4.0.0 and 4.0.3 and they all work fine. 4.1.0 doesn't.
I am attaching the logs for 4.0.3 and 4.1.0, and downgrading temporally to 4.0.3.
- ums_dbg_410.zip
- Log for 4.1.0
- (33.82 KiB) Downloaded 646 times
- ums_dbg_403.zip
- Log for 4.0.3
- (35.79 KiB) Downloaded 612 times
Re: External subtitles worked on 4.0.3 but don't on 4.1.0
+1, this issue is brought back to my Samsung TV, was working fine in 4.0.3,MikMik wrote:I noticed yesterday that some videos with external subtitles that used to work fine with UMS 4.0.3 now don't work with 4.1.0.
Same here, Samsung H Series, UE40H5500AW, was solved in 4.0.3, not working now. There was an update of the samsung tv firmware just now, i only checked after doing the update...
Thanks guys, I've fixed that now and it will be in 4.1.1
Re: [Solved] External subs worked on 4.0.3 but don't on 4.1.
Here's a preview, would be great if you can confirm the fix
http://www.spirton.com/uploads/UMS/UMS-e1bc7cc.exe
Tested, it's fixed!SubJunk wrote:Here's a preview, would be great if you can confirm the fixhttp://www.spirton.com/uploads/UMS/UMS-e1bc7cc.exe
Great, thanks for confirming
