No audio when playing mp4 file with HE-AAC
First of all I'd like to thank SubJunk for this great tool. Keep up the good work
Now here's my problem:
I got downloaded some music videos from http://www.muzu.tv as mp4s. Here's one example:
Vollständiger Name : G:\Videoclips\J\Jamiroquai\Jamiroquai - Cosmic Girl.mp4
Format : MPEG-4
Format-Profil : Base Media
Codec-ID : isom
Dateigröße : 46,5 MiB
Dauer : 3min 59s
Modus der Gesamtbitrate : variabel
Gesamte Bitrate : 1 627 Kbps
Kodierendes Programm : Lavf51.12.2
Kommentar : FlixEngineLinux_8.0.10.1 (www.on2.com)
Video
Format : AVC
Format-Profil : [email protected]
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für ReFrames : 1 frame
Codec-ID : avc1
Codec-ID/Info : Advanced Video Coding
Dauer : 3min 59s
Bitrate : 1 496 Kbps
Breite : 640 Pixel
Höhe : 360 Pixel
Bildseitenverhältnis : 16:9
Modus der Bildwiederholungsrate : konstant
Bildwiederholungsrate : 25,000 FPS
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.260
Stream-Größe : 42,7 MiB (92%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format-Profil : HE-AAC / LC
Codec-ID : 40
Dauer : 3min 59s
Bitraten-Modus : variabel
Bitrate : 128 Kbps
Kanäle : 2 Kanäle
Kanal-Positionen : Front: L R
Samplingrate : 44,1 KHz / 22,05 KHz
Stream-Größe : 3,66 MiB (8%)
The file playes well on the PC. When I start to watch the video using UMS and my PS3 connected via 1GBit network I can't hear any sound. I figured out that it has to be the HE-AAC stream causing the problems since other mp4s with normal AAC audio play well. I remuxed the streams into an mkv container. Playing the mkv just worked fine. It seems to be the combination of mp4 + HE-AAC streamed using tsmuxer.
As I got many of those files it would be highly appreciated if this issue could be fixed since it would be a really big effort to remux all of those yet existing files and all future files.
Thanks in advance,
hottif
Format : MPEG-4
Codec-ID : isom
Dauer : 3min 59s
Video
Format : AVC
Codec-ID : avc1
Dauer : 3min 59s
Breite : 640 Pixel
Höhe : 360 Pixel
ColorSpace : YUV
Audio
Format : AAC
Codec-ID : 40
Dauer : 3min 59s
Bitrate : 128 Kbps
Kanäle : 2 Kanäle
Thanks in advance,
hottif
