Avisynth/mencoder not working
adam
Post by adam »
When I try to use avisynth/mencoder with the LAV filters I get the following error on my ps3 : 800288E1
here is the debug.log
DEBUG 2012-09-04 19:36:01.612 [mencoder.exe-48] Attaching thread: mencoder.exe-48
DEBUG 2012-09-04 19:36:01.643 [Thread-226] MEncoder SB37 (C) 2000-2012 MPlayer Team
DEBUG 2012-09-04 19:36:01.643 [Thread-226] Custom build by SubJunk, http://www.spirton.com
DEBUG 2012-09-04 19:36:01.659 [Thread-226] success: format: 0  data: 0x0 - 0x162
DEBUG 2012-09-04 19:36:01.659 [Thread-226] libavformat version 54.25.104 (internal)
INFO  2012-09-04 19:36:01.688 [StartPlaying Event] renderer: 192.168.1.5, file: F:\ServerFolders\Series\White Collar\Season 2\White.Collar.S02E01.720p.HDTV.x264.mkv
DEBUG 2012-09-04 19:36:02.355 [Thread-226]
DEBUG 2012-09-04 19:36:02.356 [Thread-226] Exiting...
DEBUG 2012-09-04 19:36:02.355 [Thread-225] ============ Sorry, this file format is not recognized/supported =============
DEBUG 2012-09-04 19:36:02.356 [Thread-225] === If this file is an AVI, ASF or MPEG stream, please contact the author! ===
DEBUG 2012-09-04 19:36:02.356 [Thread-225] Cannot open demuxer.
INFO  2012-09-04 19:36:02.390 [mencoder.exe-48] Process C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe has a return code of 1! Maybe an error occurred... check the log file
DEBUG 2012-09-04 19:36:04.262 [Buffered IO End Checker] Stopping process: mencoder.exe-48
INFO  2012-09-04 19:36:06.789 [StopPlaying Event] renderer: 192.168.1.5, file: F:\ServerFolders\Series\White Collar\Season 2\White.Collar.S02E01.720p.HDTV.x264.mkv
DEBUG 2012-09-04 19:37:40.442 [UPNP-AliveMessageSender] Sending ALIVE...
I have tried a lot of things, but nothing has helped so far. Who can help me?
*EDIT : 800288E1 : "this data type is not supported"
adam
Re: Avisynth/mencoder not working
Post by adam »
I have noticed that avisynth/mencoder only works with some movies and it it doesn't work with others. On my server I have ums 1.50 installed.
Does that video play on your computer? It's likely it is corrupted in some way so MEncoder can't read it
adam
Post by adam »
All videos i have, they play on my computer. I can transcode all videos with mencoder but not with avisynth/mencoder. The main reason i tried to transcode my videos with avisynth/mencoder is because i'm looking for a way to transcode my videos with no heavy cpu load. ums is installed on a hp microserver with a dualcore 1.5ghz and this give me stuttering while i'm streaming videos.
But i think there's a bug in avisynth/mencoder?
It's hard to tell without a full debug.log but the next thing I would try would be to make sure your computer's codecs are in order. I recommend uninstalling all codec-related things, restarting the computer, installing k-lite mega with the "lots of stuff" option, restarting the computer, then trying again.
