[Solved] Wrong cover art aspect ratio
MikMik
Post by MikMik »
I have a Samsung F6200 TV. It used to not show thumbnails and cover art, but with version 4.2.1 it does (I've skipped some versions, so it might have been earlier).
However, the cover art shows with a wrong aspect ratio (stretched horizontally). The thumbnails generated from the videos are most of them right, but not the cover art taken from the cover art folder.
I think it's a Samsung related issue, because on BubbleUPnP, on my phone, they show just fine.
(29.88 KiB) Downloaded 424 times
Re: Wrong cover art aspect ratio
Thanks for posting about this. We don't currently have the ability to add padding to custom cover art images to correct aspect ratios. You can do it yourself by adding black borders to the left and right of the images if you want :)
MikMik
Post by MikMik »
Ok, thanks!
