Getting UMS to scale to more cores?
Raident
Post by Raident »
I don't know if it's the hardware, the platform, the application, or the videos themselves, but I can't get UMS to use more than 4 threads when transcoding. Is there a setting somewhere that controls this?
SharkHunter
Re: Getting UMS to scale to more cores?
Post by SharkHunter »
Check under the "Transcoding settings" tab. There is a setting there that controls the number of threads to use.
Raident
Post by Raident »
Hmm, it's correctly set to 8, but CPU usage hovers around 50-60% while transcoding, according to Task Manager.
If you look at the performance tab in task manager, you can see if it's actually using all cores, since it might be that it's using 50-60% of the total CPU power while using all cores
Raident
Post by Raident »
Rather than using all cores equally, it seems to have pegged 1 core heavily:
CPU Usage.png (184.58 KiB) Viewed 10233 times
I take it there's a bottleneck somewhere?
There's no reason it should use 100% CPU unless there are performance issues and it's struggling to transcode, are there performance issues?
Raident
Post by Raident »
Scenes involving panning/zooming tend to stutter, even over a wired gigabit connection...
