[Solved] Program won't start?
MrH
Post by MrH »
I've been using the program for awhile now and everything has been fine until today, for some reason it won't open. Javaw.exe shows up in my processes but UMS doesn't open. I have tried doing a full reinstall with no luck.
Re: Program won't start?
Which operating system and java version? Did restarting the computer fix it?
MrH
Post by MrH »
Windows 7 64, latest Java. Restarting didn't help. I reinstalled PS3 Media Server which is working fine.
Can you please attach C:\ProgramData\UMS\debug.log to the forum so I can hopefully see what's happening?
MrH
Post by MrH »
Here you go.
debug.log
(3 KiB) Downloaded 677 times
Thanks for the quick reply. I think I've fixed it now, can you please check by testing this preview version? http://www.spirton.com/uploads/UMS/UMS-dfd6e27.exe
MrH
Post by MrH »
That version seems to be working fine, cheers.
Re: [Solved] Program won't start?
Thanks for confirming!
