Xbox One no longer locating UMS
Before, I've had no problems with UMS (Previous version was 4.X.X), but yesterday when I tried to run it, the XB1 failed to find UMS. I updated UMS and the issue is still present.
- (18.23 KiB) Downloaded 961 times
Re: Xbox One no longer locating UMS
Thanks for the logs, we are looking into this now
Has any progress been made?
Have the latest update; nothing has changed.
Actually, now UMS can't find the XB1 at all.
My 360 doesn't recognise it either, even though UMS can see the 360. I can access my laptop directly, so the connection's fine, and rolling back to 4.4 works too, so I'm sticking with the earlier version until this is sorted.
UMS can see the XB1 again (Albeit, the fancy picture isn't coming up like before), but the XB1 itself can't see UMS still.
Please make logs using this version of UMS, it is a build made specifically for debugging this issue: http://www.spirton.com/uploads/UMS/UMS-764ce59.exe
