7-Zip Support
sjpirri
7-Zip Support
Post by sjpirri »
Any plans for 7-zip (LZMA/LZMA2) support as 7-zip has the highest compression ratio
Re: 7-Zip Support
I'll add it to the list but it will be a low priority because 7zip isn't too popular. I mostly see .zip, .rar and .tar.gz/.tgz files around.
It is a good idea because you're right about the better compression but there are more urgent things to do :)
Thanks for posting!
sjpirri
Re: 7-Zip Support
Post by sjpirri »
Thanks for adding it i really appreciate all the stuff your doing :) Thanks
