RAW file Pipeline option
Hi!
My AV Receiver is located on wire at my LAN.
My BD Player is also located at LAN..wired
In my opinion, it's senseless to re-encode a mp3 or a mkv file for a device, which can do it itself, you understand me?
Look at the attached jpg for the senseless traffic.
It's playing actually a stereo mp3 file encoded with LAME 3.98.4 -V 0, 249 kbps avg.
The UMS blows traffic out of proportion.
I'm scared to watch a 1080p dts movie over ums
Here is my request:
Can you implement a "raw file pipeline" function, like Samba use. All the receivers and players are build to reencode itself a stream.
Nevertheless the gadgets with imdb plugins etc. are funny
Here is my request:
- Bildschirmfoto 2015-04-22 um 13.44.49.jpg (19.87 KiB) Viewed 7227 times
Re: RAW file Pipeline option
There is already a no encoding option in the TRANSCODE folder which will stream the file as-is.
