Video Support for Yamaha Receivers
YamahaUser
Post by YamahaUser »
Is it possible to add video streaming support in Yamaha receivers? The current renderer config files only support audio for the receivers.
Re: Video Support for Yamaha Receivers
Sure, we can add it with your help. Which receiver do you use? And does your manual list the types of formats it supports over DLNA?
