100% CPU, UMS transcoding when it should not...
I would like to report some "strange" UMS behavior since version 5.1.2, and still occurring in both 5.1.3 and 5.1.4 versions, but last version it was NOT observed it was 5.0.0 ( I have not tested version 5.1.1):
very high CPU usage, near 100% on both processors when streaming videos.
It has something to do with transcoding: MEncoder and FFmpeg, according to Task Manager CPU usage.
My UMS is set up not to transcode m2ts and vob files. Also, it is set to use LPCM, AC3 and DTS audio (AV system supports them).
In version 5.0.0 it does not occur.
Also, in ver 5.0.0 my AV system: Yamaha RX-V773WA is showing correct Yamaha icon, however in later mentioned versions, this icon changes to Streamium icon, unless Streamium renderer is unchecked.
Attaching trace logs for both 5.0.0 and 5.1.4 versions.
- ums_dbg_514.zip
- (48.38 KiB) Downloaded 455 times
- ums_dbg_500.zip
- (42.54 KiB) Downloaded 490 times
