Couple renderers without good profile
I have LG UHD TV and old Samsung B series LCD tv and Galaxy S5 Active and Galaxy Note Pro 12.2" (SM-P905),none of them has own,right conf.
Can you make it to those?
What you need,log files for eatch playing something?
Also,for most of them,id liked to disable transcoding,they play anything i toss at them,except UHD dont play MP4 (and even that might be just isolated MP4 case).How you do that?
Re: Couple renderers without good profile
Log files:Basically,with latest BubbleUpnP/MxPlayer both Samsung Note Pro 12.2" (SM-P905) and Samsung S5 Active works ok,so i guess those might be excluded...
Here ar both TV-s and phone and tablet logs.
I notice,that TV-s both refused to play a lot of files,mostly in MKV format,with UMS.Those were played sucessfully with Twonky (i used it before,but it sucks)....
Edit:nvm those logs,somehow test logs were lost and overwritten.I have to run this shit again....
Added right log files
- (1.37 MiB) Downloaded 454 times
LG 65LA965W tv and Samsung LE37B650T2 ..basically LG LA965W and Samsung LE-B650 tv-s
Log was made used DefaultRenderer.conf
Fidled here around....But,those dont force themelves,dont knew why,also ALL MKV is borked for TV-s playback
Samsung-Galaxy S5 Active.conf
- (1.92 KiB) Downloaded 457 times
Samsung LE-B650.conf
- (1.5 KiB) Downloaded 454 times
LG-LA965W.conf
- (1.56 KiB) Downloaded 416 times
Instead my confs.it uses wrong ones...how i knew they wrong...well,it starts to transcode,what i dont want.There are occasions,when 2 different TV sets are served,but this is my gaming pc,i need that cpu power.
Please look at my confs,and fix them...its max "level" i could figure myself
Please follow this http://www.universalmediaserver.com/faq ... erSupport1 ? The User-Agent: DLNADOC/1.50 is too generic that it can match everything. To help you we need logs for all your TVs and a list of formats they support.
