Flac files appears twice in DLNA client browser
Universal Media Server 2.0.0
Win7 32bit/SP1
DLNA clients WD TV Live, Android 4.0 DLNA Client
Filesystem format NTFS
Wen I browse my directories on the DLNA server using any client, the files appears twice?
The files are places locally on the server running the Media Server
Win7 32bit/SP1
- Dump af flac format from VLC. Sorry about the text being in danish
- flac format.PNG (33.99 KiB) Viewed 13480 times
- Directory content on server. Lots of pictures related to the music.
- Directory content.PNG (148.26 KiB) Viewed 13480 times
- Screenshot from my Android 4.0 DLNA Client
- 2012-11-21-16-45-31-127.png (97.83 KiB) Viewed 13480 times
Re: Flac files appears twice in DLNA client browser
Problem still exists after upgrade to 2.1.0
Problem still exists on 2.1.2
debug.log
- (21.71 KiB) Downloaded 598 times
Flac files appearing twice for me running v.2.3.0 - even if there are only .flac files present in folder and no .cue or .m3u file/folder in sight.
Duplication appears in Oppo BDP-105, Marantz (aka Denon) SR7005 and WD TVLive.
Didn't happen with Serviio
I have no such problem, very weird. Checked if .cue or .m3u are possibly hidden files? I see duplicated files only when .cue is present - I have no .m3u anywhere.
Deifnitely no .cue files in folder, hidden or otherwise.
Even tried deleting all ID-tag info from .flac file in case that was being picked up - no change, still showing up twice in client browsers.
Very strange.
UPDATE -
.flac files will stream and play on Oppo, Marantz and WD TV Live (Firmware 1.13.18)
Marantz and WD TV Live play each flac file once, even if it is listed twice.
Oppo lists twice and plays twice - which is really annoying and as yet inexplicable.
Very strange.
UPDATE -
I have the same problem. ( v.2.3.0 and renderers WDTVLive, french FreeboxHD). In detail :
1- .flac files appearing twice, the first with displayed size of the compressed file, the second with size of uncompressed file ( with no .wav file in the directory)
2- Opening the .cue file (corresponding to the .flac file with N tracks)) displays :
- the titles of the N tracks (OK) + the .flac file N times (in alternate order for WDTVLive and alphabetic order for FreeboxHD)
3- Even strange. The following sequence " closing the .cue file, closing the directory that contains the .cue file, then reopening this directory and reopening the .cue file " displays twice the N tracks titles and .flac file 2 x N times !
Repeat this sequence gives le same result but three times ( N tracks three times + .flac 3 x N times) ! and so on...
This does not occur with .ape and .wav files or associated .cue files.
P.S. Same problem with PS3 Media Server.
UPDATE
Similar problem with viewing photos.
Using WEB.conf and Picasa : first display OK, but after closing and reopening the directory, the image files are listed twice, and thumbnails displayed twice too.
Repeating gives three, four, five...
There is accumulation. Where ?
UPDATE
Question to all of you.
Are You running the Mediaserver on a Win box?
I suspect the Windows Media Server to be partly responsible, causing the DLNA renderer to become confused.
I'm in the middle of changing my server to a Mac Mini, so can't verify.
I have a similar problem with DVD titles appearing multiple times actually. I get
Title 1
Title 2
Title 3
Title 1
Title 2
Title 3
Title 1
Title 2
Title 3
But sometimes the ordering is completely random. I'm running UMS on a WinXP machine, but I'm not running Windows Media Server on it just UMS
Title 1
Title 2
Title 3
Title 1
Title 2
Title 3
Title 1
Title 2
Title 3
