FFmpeg web strem on Linux
Hi, thanks for awesome software. Works great for local files.
But i want to stream web video (like youtube). On my linux nas (debian) youtube videos won't play, but on windows station ok.
I think trouble in linux version of ffmpeg.
Error message
Complete listing
dpkg -l output
Maybe i forgot to install some packages?
Thanks for help!
Error message
Desktop API is not supported on the current platform
11-24 12:54:57 Starting transcode/remux of ? ??? ????? ??? ? ??? ? ??????
11-24 12:55:01 Exception in thread "AWT-EventQueue-0" java.lang.UnsupportedOperationException: Desktop API is not supported on the current platform
11-24 12:55:01 at java.awt.Desktop.getDesktop(Desktop.java:144)
11-24 12:55:01 at net.pms.newgui.TracesTab$3.mouseClicked(TracesTab.java:167)
11-24 12:55:01 at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:270)
11-24 12:55:01 at java.awt.Component.processMouseEvent(Component.java:6139)
11-24 12:55:01 at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
11-24 12:55:01 at java.awt.Component.processEvent(Component.java:5901)
11-24 12:55:01 at java.awt.Container.processEvent(Container.java:2105)
11-24 12:55:01 at java.awt.Component.dispatchEventImpl(Component.java:4497)
11-24 12:55:01 at java.awt.Container.dispatchEventImpl(Container.java:2163)
11-24 12:55:01 at java.awt.Component.dispatchEvent(Component.java:4323)
11-24 12:55:01 at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4461)
11-24 12:55:01 at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4134)
11-24 12:55:01 at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4055)
11-24 12:55:01 at java.awt.Container.dispatchEventImpl(Container.java:2149)
11-24 12:55:01 at java.awt.Window.dispatchEventImpl(Window.java:2478)
11-24 12:55:01 at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:649)
11-24 12:55:01 at java.awt.EventQueue.access$000(EventQueue.java:96)
11-24 12:55:01 at java.awt.EventQueue$1.run(EventQueue.java:608)
11-24 12:55:01 at java.awt.EventQueue$1.run(EventQueue.java:606)
11-24 12:55:01 at java.security.AccessController.doPrivileged(Native Method)
11-24 12:55:01 at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:105)
11-24 12:55:01 at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:116)
11-24 12:55:01 at java.awt.EventQueue$2.run(EventQueue.java:622)
11-24 12:55:01 at java.awt.EventQueue$2.run(EventQueue.java:620)
11-24 12:55:01 at java.awt.EventQueue.dispatchEvent(EventQueue.java:619)
11-24 12:55:01 at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:275)
11-24 12:55:01 at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:200)
11-24 12:55:01 at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
11-24 12:55:01 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:185)
11-24 12:55:01 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:177)
11-24 12:55:01 at java.awt.EventDispatchThread.run(EventDispatchThread.java:138)
11-24 12:55:08 There is no inputstream to return for ? ??? ????? ??? ? ??? ? ?????? [FFmpeg Web Video]
root@debian:/home/ums# dpkg -l | grep ffmpeg
ii ffmpeg 5:0.7.13-dmo2 audio/video encoder, streaming server & audio/video file converter
ii libavdevice52 5:0.7.13-dmo2 ffmpeg device handling library.
ii libavformat52 5:0.7.13-dmo2 ffmpeg file format library.
ii libavutil49 4:0.5.6-3 ffmpeg utility library
ii libswscale0 5:0.7.13-dmo2 ffmpeg video scaling library.
Thanks for help!
