Migration from PMS-SB
SergioBigRed
Post by SergioBigRed »
I was an avid fan of PMS and SB releases.
I am now eager to test UMS but don't want to lose all the settings I carefully tuned over the years on my PMS.
Is there the opportunity to migrate these to UMS?
I see that the UMS.conf file is lighter than the old one with entries I don't recognize... Should I move everything to UMS rewriting from scratch?
Is there the opportunity to use pmsencoder or the UMS will use VLC directly so need of it anymore for web streaming?
Thanks!
Re: Migration from PMS-SB
Hi Sergio, welcome to the forum :)
I recommend starting with a fresh config, because the settings that may have been good years ago might not be the best anymore. You can always enable your old settings in the program itself.
PMSEncoder still works with UMS (as do all plugins)
