[Solved] h.265 on Samsung TVs
dude373
Post by dude373 »
I have a UA46ES5600 that defaults to the Samsung-nonCD.conf and a UA46f5500 that defaults to the Samsung-CD.conf.
I am trying to play h.265 on them as h.264 and actually succeeded once by adding some code, but have since lost that setup.
Ex: suits.s05e07.720p.hdtv.hevc.x265.rmteam.mkv
Can you help me?
Wolfgan
Re: h.265 on Samsung TVs
Post by Wolfgan »
Try to create an specific profile for each TVs so you can tweak & optimize the settings. Follow http://www.universalmediaserver.com/faq ... erSupport1 (easier to start your own profile from any of the closer existing ones, ie copy and modify a Samsung series F and ES profile to your needs)
Supermanfan77
Post by Supermanfan77 »
julietzhu520 wrote:HEVC (High Efficiency Video Coding or H.265) is one of the most important technologies to have emerged in the TV industry in the last decade. However, H.265/HEVC, as the newest codec has not been accepted by these 4K TVs yet. It is necessary for us to transcode H.265/HEVC videos for playback on 4K HD TV with a professional H.265/HEVC encoder/decoder
In other words use a program that converts the H265 file into a container the HDTV can play? UMS already does that so there's no need for a separate program.
Wolfgan
Post by Wolfgan »
I have an h6400 and made some tests with h265/hevc files and worked OK thru UMS, no transcoding required (it's preconfigured already in the profile BTW https://github.com/UniversalMediaServer ... H6400.conf).
dude373
Post by dude373 »
Thanks. I replaced/added these lines to my config. Seems to work for h.265 on my Samsung 46f5500.
Supported = f:mpegps v:divx|h264|mjpeg|mp4|mpeg1|mpeg2|sor|vc1|vp6|wmv a:aac|aac-he|ac3|adpcm|dts|eac3|lpcm|mp3|wma m:video/mpeg
Supported = f:mpegts v:divx|h264|h265|mjpeg|mp4|mpeg1|mpeg2|sor|vc1|vp6|wmv a:aac|aac-he|ac3|adpcm|dts|eac3|lpcm|mp3|wma m:video/mpeg
MPEGTS-H265-AC3 H.265 (HEVC) AC-3 MPEG-TS Only FFmpeg outputs H.265, others will output H.264
MPEGTS-H265-AAC H.265 (HEVC) AAC MPEG-TS Only FFmpeg outputs H.265, others will output H.264
SamsungLED46.conf
(3.31 KiB) Downloaded 1670 times
alesk76
Post by alesk76 »
@dude373
thx for this file I have use it on my Samsung UE55HU8500TXXU and it Works but It can not be done moving by movie timeline forward or backword...
when movie starts it show the line and it is done 3sec of it and then movie runs if you try something it jups to the start of the movie...
If you leavi it movie Works to the end....
please for help and if somebody know to do good configuration fike with hevc / HDtrue sound support for Universal media server striming support for Samsung UE55HU8500TXXU i would be very happy...
also a few steps how to use (where to copy those files in Windows 10 would be nice... a lot of fols doesnt know how to do that...
best regards
alesk76
Gloriaivy
Post by Gloriaivy »
I know some 2016 Tizen-based Samsung models supports to play H.265 with MKV, MP4 or MPEGTS container.
alesk76
Post by alesk76 »
I have now QE55Q7FNATXXH
I have problems with my 4K movies .. what do I have to do.. is any specific file or what… ?
please for help….
