FFmpeg is broken in v5.3.0 and in ums builder
FFmpeg is broken in v5.3.0 and in ums builder.
any video will not start if i choose ffmpeg in 5.3.0 and ums builder.
In v5.2.1 ffmpeg is ok.
So i do this: i take ffmpeg and ffmpeg64 from 5.2.1 and copy paste into 5.3.0.
Re: FFmpeg is broken in v5.3.0 and in ums builder
Please follow the red instructions above.
I have also issues with my PS3 and FFmpeg on newer Versions of UMS. When I use FFmpeg without the "switch to tsMuxeR" UMS stopps immediately after starting the file and my PS3 says that the file format is not supported. With the "tsMuxeR" option on it plays on my PS3 but audio and video are out of sync. In UMS version 1.2 everything works fine but the later Versions have this issue.
I added the log files for the issue on UMS 5.3. First Playback is without tsMuxeR option. The second is with the option.
Btw this happens only on my PS3. With my Panasonic TV I have no issues at all.
- (88.93 KiB) Downloaded 579 times
