Installation, java memory setting
SuperDre
Post by SuperDre »
After I used 1536 as memory setting I get an 'cannot create java blahblah' when I try to start UMS using the exe.. Starting UMS using the UMS.bat with the same -Xmx1536M setting it just runs. Reinstalling UMS with the default setting of 768 it works again. So I guess something is wrong with the setting in the installation.
Re: Installation, java memory setting
I'll let SharkHunter handle this since it's his feature :)
S7eele
Post by S7eele »
May not be worth much but I am using the UMS.bat with 1536 and have not had a problem.
Peace!
