[6.0.0-a1] Log tab bottom tooltips in maximized UMS window misbehavior.
Tianuchka
Post by Tianuchka »
Hello, guys!
My system is:
Win 7 x64,
UMS 6.0.0-a1,
Java 8 update 66 x64.
I've experience a little confusion with the Log tab bottom tooltips in maximized UMS window.
I mean, what in the maximized UMS window the bottom tooltips on the Log tab covers some elements of the user interface (UI) until I roll my mouse's pointer over any other element of UI with the tooltip.
Please, take a detailed look into the attachments.
01. Normal state of the UI elements in the maximized UMS window.
FireShot Pro Screen Capture ?074.jpg (304.55 KiB) Viewed 7891 times
02. The tooltip covers the UI elements in the maximized UMS window untill I roll mouse over any other UI element with another tooltip.
FireShot Pro Screen Capture ?075.jpg (307.03 KiB) Viewed 7891 times
03. No problems with the UI elements in the minimized state of the UMS because the tooltip is outside of the main UMS window.
FireShot Pro Screen Capture ?076.jpg (293.43 KiB) Viewed 7891 times
04. One tooltip with the same text for two different UI elements.
Image Image
Re: [6.0.0-a1] Log tab bottom tooltips in maximized UMS window misbehavior.
We're aware of the problem but haven't found a cure. It's not limited to the "Logs" tab, it's any tooltip that's placed close to the edge of the screen, and it's not a UMS issue it's a Java/Swing issue.
Tianuchka
Post by Tianuchka »
Nadahar wrote:We're aware of the problem but haven't found a cure. It's not limited to the "Logs" tab, it's any tooltip that's placed close to the edge of the screen, and it's not a UMS issue it's a Java/Swing issue.
Ok, sorry for my wrong complaint ))
Let's hope it will be resolved in the new versions of the Java/Swing.
This topic could be closed, I guess!
Nothing wrong about it, the issue is most definitely there ;) I'm just saying that we're aware of it, but haven't solved it (yet).
