[LiveSubtitles] not showing on a Samsung SmartTv
Hello everyone,
I am unable to see the subtitles when I select them on my Samsung Tv. Do I need to configure anything or it shoud appear out of the box ? I do see lot of subtitle options when I go inside that menu, but none of them display anything. Help welcome !
Re: [LiveSubtitles] not showing on a Samsung SmartTv
What Samsung Model ? Is it J Model? , because then it's related to this post
ok I'll hijack this thread cause I've the same issue and Op is missing
I can't see live subtitles, but the same subtitles downloaded and placed in video folder works fine.
Model: samsung ue40h5303
in the attached log u'll find my first try with live subtitles playing "nikita" (not working)
and the second try with .srt file in the same folder playing "the 100" (working)
I'm adding the result of getprotocolinfo from devicespy in case it's needed
Any idea? thx
Any idea? thx
device_spy.txt
- (55.57 KiB) Downloaded 510 times
- (70.43 KiB) Downloaded 533 times
bump, can anyone check my logs a tell me if there's something useful?
seems it is: UN40J5500squadjot wrote:What Samsung Model ? Is it J Model? , because then it's related to this post
what now ?
Also, unable to make channels plugin work !
I don't know, i hoped the developers would have something to add herekpoman wrote:what now ?
