LG Blu-ray player, BP series (32x,42x,62x, etc...)
HI all,
As I got a LG 420, I decide to create the media render conf file.
I do not know the validation processs... But I begin from the WDLive and create this one (I do not find where is the repository of the picture so, it use the WDLive picture !).
Everything is working fine, due to the fact that LG player can do nearly the same thing like the WDLive box.
Advice me how can I help ?
Regards.
Sebos
# Profile for LG-BP.
RendererName=LG BP
# LG BP
# User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
UserAgentSearch=IPI/1.0 UPnP/1.0 DLNADOC/1.50
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeVideo=MPEGPSAC3
TranscodeAudio=WAV
DefaultVBVBufSize=false
MuxH264ToMpegTS=false
MuxDTSToMpeg=true
WrapDTSIntoPCM=false
MuxLPCMToMpeg=false
MaxVideoBitrateMbps=0
MaxVideoWidth=0
MaxVideoHeight=0
TranscodeExtensions=flv
StreamExtensions=avi,xvid,divx,avc,mpg,mpeg,mkv,mp4,264,ts,tp,m2t,m2ts,wmv,mp3,wav,pcm,lpcm,wma,aac,flac,mka,aif,aiff,ogg,dts
# Show the duration of a DVD Title in the overview
ShowDVDTitleDuration=true
# CBR bitrate. Needed for byteseek to timeseek convertion. 0 = disabled.
CBRVideoBitrate=15000
# Number of seconds to rewind every time we do a byteseek to timeseek conversion.
# If the conversion isn't 100% accurate so a little rewind can be nice
ByteToTimeseekRewindSeconds=0
Regards.
Sebos
RendererName=LG BP
# LG BP
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeAudio=WAV
MuxDTSToMpeg=true
MuxLPCMToMpeg=false
MaxVideoWidth=0
MaxVideoHeight=0
- PNG picture of LG BluRay BP-xxx
- large01_result.png (14.63 KiB) Viewed 14533 times
LG-BP.conf
- media conf for LG (copy from WDLive)
- (1.05 KiB) Downloaded 748 times
(freebox v5, LG Blu-ray BP420, Sony Bravia)
Re: LG Blu-ray player, BP series (32x,42x,62x, etc...)
Hi sebos, thanks a lot for this! Unfortunately it seems that the user-agent is too generic, meaning that other renderers use it too. Is there any other identifying info given?
HI Subjunk, thanks for the answer, I believed nobody wanted to play with LG Blu-ray
So, yes you're right... but if you look at the available renders in UMS, you will see that there is already Visio Smart TV... which use unfortunatly this generic string.
I think this string is generic enough to try to do a better renders conf file: I mean something with everything is sent without any transcoding...
This will permit to LG players (and I pretty sure, other ones) to play files with UMS.
Because, if I look at the trace sent by the LG player... I do not find anything more than (condition to reproduce: remove the VizioSmartTV.conf or rename it) :
What do you think SubJunk ?
ACE 2013-03-14 18:46:26.574 [New I/O server boss #1 ([id: 0x63cea096, /192.168.0.10:5001])] Creating new pipeline
TRACE 2013-03-14 18:46:26.575 [New I/O server worker #1-4] Opened request handler on socket /192.168.0.18:42204
TRACE 2013-03-14 18:46:26.576 [New I/O server worker #1-4] Request: HTTP/1.1 : GET : description/fetch
TRACE 2013-03-14 18:46:26.576 [New I/O server worker #1-4] Received on socket: CONNECTION: Keep-Alive
TRACE 2013-03-14 18:46:26.576 [New I/O server worker #1-4] Received on socket: DATE: Thu, 14 Mar 2013 17:46:25 GMT
TRACE 2013-03-14 18:46:26.577 [New I/O server worker #1-4] Received on socket: HOST: 192.168.0.10:5001
TRACE 2013-03-14 18:46:26.577 [New I/O server worker #1-4] Received on socket: USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50
TRACE 2013-03-14 18:46:26.579 [New I/O server worker #1-4] Using default media renderer: Unknown renderer
INFO 2013-03-14 18:46:26.579 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
TRACE 2013-03-14 18:46:26.580 [New I/O server worker #1-4] HTTP: description/fetch / 0-0
Hello i modified your conf file with a better UserAgent find with log in Debug (just need to "delete" LGST600.conf file before) and change some parameters
So here is
So here is
RendererName=LG-BDP Series
# You must create a folder icons in the ums installation folder and put picture in.
RendererIcon=icons/LGBDP.png
# LG BP
UserAgentSearch= LG-BDP Linux/2.6.35 UPnP/1.0 DLNADOC/1.50 LGE_DLNA_SDK/1.5.0
Video=true
Audio=true
Image=true
SeekByTime=true
TranscodeAudio=LPCM
MediaInfo=true
MuxH264ToMpegTS=true
MuxDTSToMpeg=true
WrapDTSIntoPCM=true
MuxLPCMToMpeg=true
MaxVideoWidth=0
MaxVideoHeight=0
H264Level41Limited=true
# CBRVideoBitrate=15000
# ByteToTimeseekRewindSeconds=0
LG-BP.conf
- (1.34 KiB) Downloaded 703 times
Bbox
Blu Ray: LG BP420
TV: LG 55LM615S
Blu Ray: LG BP420
TV: LG 55LM615S
If a User Agent configuration of a device gets in your way, you can configure UMS to ignore it, so that it finds your correct device.
You can find this ignore property in the General Configuration tab, 3rd line from the bottom.
This way you don't have to remove unwanted .conf files.
Goog tip
My method was more barbarian XD
Bbox
Blu Ray: LG BP420
TV: LG 55LM615S
Blu Ray: LG BP420
TV: LG 55LM615S
I cant play and movies on my lg bh 6440 blu ray player. Why is that?
