Multiple Network
KeLLeYLeK
Multiple Network
Post by KeLLeYLeK »
I have two networks (ip group) in my home. One of them is cable, it start with 192.168.1.xxx subs; the other is wireless and behind the access point and start with 192.168.0.xxx. When i have started the UMS, the socket created in 192.168.1.xxx:5001. So all the DNLA enabled TVs in this sub see the UMS . But the others (behind the access point and have 192.168.0.xxx sub) not see the UMS.
How can I configure (if it is possible) the UMS to use multiple subs - networks in same instance.
Thanks.
KeLLeYLeK
Optimus_prime
Re: Multiple Network
Post by Optimus_prime »
Change the subnet on your UMS host device to be 255.255.0.0
That should fix your problem.
KeLLeYLeK
Post by KeLLeYLeK »
Optimus_prime wrote:Change the subnet on your UMS host device to be 255.255.0.0
I have changed PC's (that run the UMS) ethernet subnet as you told.
But, i have lost both subs of DLNA devices (TVs in 192.168.1.xxx subs also not see the UMS).
Am i misunderstanding what you say or ... ?
Optimus_prime
Well, i will try what you have set up here and i'll see if i can find a fix. I would assume your not trying to run one instance of UMS for both devices at the same time?
Optimus_prime
Sorry mate i hope you don't think i'm ignoring you but i'm still doing some testing.
Optimus_prime
Interesting,
so i've been testing my network config, i'll lay it out to be specific:
1 device on a 192.169.1.something network (Samsung UA55D7000 to be exact)
UMS server on a 192.168.0.something network (Also the paystation in the screenshot is on the 192.168.0.something network)
Both on a 255.255.0.0 subnet
So in theory they should all play nicely. Whilst im not a networking engineer i do know my way around my own network (I run a suite of Cisco gear), for the life of me i can't get UMS or more to the point the device to show UMS.
I've attached a screenshot of the fact that UMS can see the TV and i can ping the shit out of it but i wont display UMS like normal.
Anyone else have any suggestions, i'm open for anything at this point.
UMS-Subnet trial.jpg (179.63 KiB) Viewed 10326 times
KeLLeYLeK
Post by KeLLeYLeK »
Optimus_prime wrote:Well, i will try what you have set up here and i'll see if i can find a fix. I would assume your not trying to run one instance of UMS for both devices at the same time?
Thanks for your support. I'm trying to run one isstance of UMS for both device at different times but with same config. With same config, i can not succeed.
When i have changed network settings (force networking + force IP), both device have worked with alternate config.
By the way, is it possible to run multiple instance of UMS? If so, how?
Thanks again.
