Videos Not Showing Up on Xbox360
This is a super odd one.
I just did a fresh install of Windows yesterday. Set my codecs back up, installed Java, installed UMS 2.4.0
I've been using UMS for a long, long time.
I've never had this issue before and I'm getting really frustrated so hopefully it's something stupid simple that I'm overlooking.
Everything is setup and networked as usual. I have my folder shared the way it's always been. My XBOX360 sees UMS but when I go to open it, the xbox just shows a blank directory with no videos, folders or files.
Log file is clean with no issues.
Firewall (router) has an exception set for ports 5001 and they're set to forward to my system. I've added exceptions for port 5001 UPD and TCP into the windows firewall just in case.
I get no errors anywhere, just a blank list with no videos where I used to get the entire contents of the shared folder and subfolders within.
This is FRUSTRATING
This is FRUSTRATING
Re: Videos Not Showing Up on Xbox360
I'm also experiencing this issue. I did an update and now I can see any of my video despite changing no settings. I pulled the installation and did a clean install but still show the same thing. I select Universal Media Server from Xbox 360's Video Player, but it comes up as if I had shared no videos at all. I've attached the log from my server, hopefully that will provide some insight.
- Debug Files with issue.
- (12.29 KiB) Downloaded 687 times
- SharkHunter
- Developer
Pls redo the failing thing with TRACE set as log level. See here viewtopic.php?f=9&t=556djchateau wrote:I'm also experiencing this issue. I did an update and now I can see any of my video despite changing no settings. I pulled the installation and did a clean install but still show the same thing. I select Universal Media Server from Xbox 360's Video Player, but it comes up as if I had shared no videos at all. I've attached the log from my server, hopefully that will provide some insight.
- Contact:
Same issue here. Seems fine on the PS3.
I'm having the same issue with videos not showing up on my Xbox 360 in 2.4.0 and 2.4.1. Attached are my 2.4.1 TRACE level log files.
- (15.33 KiB) Downloaded 778 times
Updated to 2.4.1 still experiencing the same issue. The Xbox is seeing the server but request being made seem like it's not responding with the directories designated.
- Trace Level Log for UMS 2.4.1
- (18.31 KiB) Downloaded 620 times
Can you also attach the debug info for the last version that works? (I assume 2.3.0?)
Done, attached trace log after testing on 2.3.0. Video streams fine and clean with most settings set to their defaults. I only set the Ethernet adapter and the renderer on UMS and was able to successfully navigate through all my directories since I had not set my folders to only expose the one directory I normally use.SubJunk wrote:Can you also attach the debug info for the last version that works? (I assume 2.3.0?)
Please let me know if there is any other information I can gather for you to help facilitate debugging.
- Trace Log for 2.3.0
- (22.49 KiB) Downloaded 756 times
Guess I'll be uninstalling and going back to 2.3.0 for the time being.
To fix this I need you guys to test some versions for me to narrow down what caused this bug since I can't see it in the code.
Please let me know which of these (if any) causes the bug:
http://www.spirton.com/uploads/UMS/UMS-1334beb.exe
http://www.spirton.com/uploads/UMS/UMS-6584c38.exe
