Play-Fi renderer support
Klidec
Post by Klidec »
I just purchased a new receiver. the Anthem MRX720. It supports Play-Fi which seems to be a competing standard to Airplay. There is an iPhone app you can download. The app finds the receiver and treats it as a speaker that it can stream media to. In the app it can find DLNA media servers and does seem to find UMS.
Play-FI currently recommends using these media servers:
https://play-fi.com/faq/entry/recommend ... r-software
https://play-fi.com/faq/entry/supported-media-servers
Would be great if we could add UMS to the mix.
I tried playing with the renderer conf files but I really don't know what i'm doing.
Supported Audio Formats:
https://play-fi.com/faq/entry/supported ... le-quality
FAQ:
Supported products/receivers/speakers:
http://listen.dts.com/pages/play-fi
Hope this along with the debug capture is enough info.
I'd be happy to test a conf file.
thanks for the help!
(185.81 KiB) Downloaded 490 times
Klidec
Re: Play-Fi renderer support
Post by Klidec »
the attached renderer conf seems to work.
I was not able to figure out how to use Mediainfo and supported audio format statements.
But this seems to work for me.
The other issue might be around the user agent search match
UserAgentSearch = Darwin/14.0.0, UPnP/1.0, Portable SDK for UPnP devices/1.6.19
I don't think that the above will be unique enough.
Play-FiApp.conf
(26.66 KiB) Downloaded 550 times
