Onkyo TX-NR717
danielt
Onkyo TX-NR717
Post by danielt »
Here is a .conf file and image for Onkyo TX-NR717. Probably work for all Onkyo internet enabled receivers, but this is the only one I tested.
Onkyo.conf
.conf file for Onkyo renderer
(554 Bytes) Downloaded 1008 times
EDIT: Fixed typo
danielt
Re: Onkyo TX-NR717
Post by danielt »
Also, I guess I should comment I tested .mp3 and .aac. The other extensions are from the manual, but not tested. If someone can point to an audio test file hub, I'll run through several.
Optimus_prime
Re: Onkyo TX-NR717
Post by Optimus_prime »
danielt,
could you do me a favour and do a debug log (set as trace) for me so i can check what UMS see's your reciever as before i submit this as a config.
thanks helping out
danielt
Re: Onkyo TX-NR717
Post by danielt »
OP,
Is this what you are looking for:
TRACE 2013-03-03 10:24:52.534 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.556 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.578 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.599 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.621 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.643 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.664 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.686 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.708 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.729 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.751 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:52.773 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:24:59.139 [New I/O server boss #1 ([id: 0x001ae987, /192.168.15.207:5001])] Creating new pipeline
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Opened request handler on socket /192.168.15.30:32901
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Request: HTTP/1.1 : POST : upnp/control/content_directory
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Matched media renderer "Onkyo TX-NR717" based on address /192.168.15.30
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Received on socket: Connection: close
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Received on socket: Content-Length: 693
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Received on socket: Content-Type: text/xml; charset=utf-8
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Received on socket: Host: 192.168.15.207:5001
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Received on socket: User-Agent: Mediabolic-IMHTTP/1.8.225 UPNP/1.0 DLNADOC/1.50
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] Recognized media renderer: Onkyo TX-NR717
TRACE 2013-03-03 10:24:59.141 [New I/O server worker #1-6] HTTP: upnp/control/content_directory / 0-0
TRACE 2013-03-03 10:24:59.142 [New I/O server worker #1-6] discover 0 refresh forced: true
TRACE 2013-03-03 10:24:59.143 [New I/O server worker #1-6] End of analysis
TRACE 2013-03-03 10:24:59.146 [New I/O server worker #1-6] Sent to socket: Content-Length: 4767
TRACE 2013-03-03 10:24:59.146 [New I/O server worker #1-6] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2013-03-03 10:24:59.146 [New I/O server worker #1-6] Sent to socket: Server: Windows_7-x86-6.1, UPnP/1.0, UMS/2.4.2
TRACE 2013-03-03 10:25:16.771 [UPNPHelper] Receiving a NOTIFY from [192.168.15.15:1900]
TRACE 2013-03-03 10:25:16.772 [UPNPHelper] Receiving a NOTIFY from [192.168.15.15:1900]
TRACE 2013-03-03 10:25:22.540 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.562 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.583 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.605 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.627 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.650 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.671 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.693 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.715 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.737 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.758 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:22.780 [UPNPHelper] Receiving a NOTIFY from [192.168.15.30:1900]
TRACE 2013-03-03 10:25:41.770 [UPNPHelper] Receiving a NOTIFY from [192.168.15.15:1900]
TRACE 2013-03-03 10:25:41.771 [UPNPHelper] Receiving a NOTIFY from [192.168.15.15:1900]
TRACE 2013-03-03 10:25:41.772 [UPNPHelper] Receiving a NOTIFY from [192.168.15.15:1900]
Optimus_prime
Re: Onkyo TX-NR717
Thanks for that danielt.
It looks as if this conf will work for most if not all Onkyo Network enabled Receivers.
I'll submit it as a generic Onkyo reciever conf until something better is submitted
Thanks again submitting it mate.
Re: Onkyo TX-NR717
Thanks for this!
nambit
Re: Onkyo TX-NR717
Post by nambit »
Thank you for this! Wow, this release worked perfectly for me! :) :) :)
cheesenips
Re: Onkyo TX-NR717
Post by cheesenips »
I am currently own a Onkyo TX-NR515. I have downloaded the onkyo.conf that is on this page -- but I cannot get it to work.
I have also gone in and deleted user-agent infomation from the .conf and rebooted UMS and checked the trace log to see if I could see the identifiers for the onkyo recevier. So far nothing.
Anyone have any ideas?
I cant see why this would not work. the 515 is also DLNA compliant. FOr what its worth the onkyo sees windows media center.
Any help would be great.
-Cheesenips
Optimus_prime
Re: Onkyo TX-NR717
Could you do me a log as per this post viewtopic.php?f=9&t=556
That way we can see if we can put a .conf that may fix your issues
cheesenips
Re: Onkyo TX-NR717
OK .. I hope i did this right.
My Onkyo receiver is on and I am looking at the DLNA screen. It currently shows Keith-PC (windows media center).
UMS does not show the onkyo as a renderer (coincidentally it shows nothing as of this writing). Now if i fire up my PS3 -- the ps3 shows up as a renderer (using forced Adapter/IP/Port) and works great.
I don't know what else to do regarding "reproducing the bug" as it just is not working. I have powered off all devices and restarted them several times before I made my first post, in the hopes that that may help, but it didn't.
If there is something i need to try - please let me know.
THanks for the help.
-Cheesenips
(14.93 KiB) Downloaded 602 times
