Ability to Choose which Config for each Device
counsil
Post by counsil »
SubJunk,
I think it would be awesome to add a new tab to UMS with the ability to show a list of all the devices (probably IP would be best) that has been found, then a dropdown box next to each showing what config file has been chosen for the device. You could even show a small icon of the device that is used on the first screen. 8-) Then give the user the ability to change which config file to use with that device. This should help with devices that don't provide good names (like the Oppo's and Denon's).
Also, it would be cool to add a checkbox to next to the device allowing (or not allowing) the device access to UMS. I know that functionality is already on another tab, but the above would be a lot more user friendly because all of the information about the device would be in one place (visually).
I hope I am making sense.
Re: Ability to Choose which Config for each Device
It's a good idea :) There are quite a few other features that I'll do before this so I'm not sure when it will get done but I'll add it to the list and thanks for giving it :)
