Hisense hle4015rtfx
lokillo_20
Hisense hle4015rtfx
Post by lokillo_20 »
I have a Smart TV Hisense 40'' hle4015rtfx. UMS recognizes me as VizioTV but don't work the transcoding. I leave the debug's files.
I don't know which profile i could try. please help me!!!
Here is the information of the manufacturer:
DMP (reproductor multimedia)
VIDEOS: Codecs: AVC, h264, x.264, XVID. Resolucion maxima: 1920x1080. Bit rate maximo: 20 Mbps. Contenedores: M2TS, AVI, TS, MKV, MPG, VOB, M2TS, MP4, MKV
SUBTITULOS EXTERNOS: SRT, SSA
AUDIO Archivos: MP3 (CON ID3), OGG
IMÁGENES Archivos: BMP, JPG, PNG
Regards!
PD: If you want more information, tell me!
(59.77 KiB) Downloaded 617 times
valib
Re: Hisense hle4015rtfx
Post by valib »
It seems that your TV has very common identification which confuses the UMS. You have to disable Vizio Smart TV at the General Configuration tab using the Select Renderers button and make your own configuration following the instruction at http://www.universalmediaserver.com/faq ... erSupport1
lokillo_20
I need some help:
1- I follow the instructions to set this:
UserAgentAdditionalHeader =
UserAgentAdditionalHeaderSearch =
the debug only show me:
Received on socket: HOST: 192.168.1.2:5001
TRACE 2016-03-20 11:25:10.653 [New I/O worker #5] Received on socket: DATE: Sun, 20 Mar 2016 14:25:10 GMT
TRACE 2016-03-20 11:25:10.653 [New I/O worker #5] Received on socket: CONNECTION: Keep-Alive
TRACE 2016-03-20 11:25:10.653 [New I/O worker #5] Received on socket: USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50
TRACE 2016-03-20 11:25:10.653 [New I/O worker #5] HTTP User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
2- I see all my movies with subtitles for then i choose transcode all the movies with subtitles but my tv freeze when I put play.
MediaInfo = false
CreateDLNATreeFaster = false
TranscodeExtensions = mp4,avi,mkv
I try with all but i have no luck
Profile Video Audio Container Notes
# MPEGPS-MPEG2-AC3 MPEG-2 AC-3 MPEG-PS VLC only outputs 2-channel AC-3 audio
# MPEGTS-MPEG2-AC3 MPEG-2 AC-3 MPEG-TS VLC only outputs 2-channel AC-3 audio
# MPEGTS-H264-AC3 H.264 (AVC) AC-3 MPEG-TS VLC only outputs 2-channel AC-3 audio
# MPEGTS-H264-AAC H.264 (AVC) AAC MPEG-TS
# MPEGTS-H265-AC3 H.265 (HEVC) AC-3 MPEG-TS Only FFmpeg outputs H.265, others will output H.264
# MPEGTS-H265-AAC H.265 (HEVC) AAC MPEG-TS Only FFmpeg outputs H.265, others will output H.264
# WMV: WMV 2 (WMV 8) WMA 2 ASF
# These profiles are supported by the MEncoder, FFmpeg and VLC engines.
# Default: MPEGPS-MPEG2-AC3
TranscodeVideo = MPEGTS-MPEG2-AC3
lokillo_20
I try too this:
MediaInfo = true
Supported = f:mpegts v:h264|avc|x.h264|xvid a:aac|ac3 m:video/mpeg
Supported = f:mp4 v:h264|avc|x.h264|xvid a:aac|ac3|mp3|mpa m:video/mp4
Supported = f:avi v:h264|avc|x.h264|xvid a:aac|ac3 m:video/avi
Supported = f:mkv v:h264|avc|x.h264|xvid a:aac|ac3|dts|mp3|vorbis m:video/x-matroska
But the half of my movies dissapear in my tv.
