Version 6.2.1 released
General:
This release improves support for Samsung and Panasonic TVs and squashes pesky bugs!
Changes since 6.2.0:
  • General:
    • Added more tooltips
    • Fixed DTS-HD being detected as DTS
    • Fixed support for embedded ASS subtitles in FFmpeg
    • Fixed minor bugs
  • Renderers:
    • Improved support for Panasonic ST60 TVs
    • Improved support for Samsung J6200 TVs
  • Languages:
    • Synchronized translations with crowdin
  • External Components:
    • Updated chromecast-java-api-v2 to 0.9.1
    • Updated FFmpeg
    • Updated Google gson to 2.6.2
    • Updated jai-imageio-core to 1.3.1
    • Updated jmustache to 1.12
    • Updated JNA to 4.2.2
    • Updated logback to 1.1.6
    • Updated slf4j to 1.7.19
Madoka
Re: Version 6.2.1 released
Post by Madoka »
Thanks for the new release!
This version fixes a problem with external .ass subtitles and complex overlays and text that had existed with FFmpeg (the text disappears too fast or doesn't display). So far, the overlays display correctly in the files I've tried to the point that I can uncheck "Defer to Mencoder" in the FFmpeg settings tab.
The new FFmpeg also works with anime with embedded fonts, as well!
Great work!!
Edit: This version/FFmpeg also plays an mkv that had subs which previous versions would have unfixable A/V sync issues.
Wolfgan
Post by Wolfgan »
Thanks for the release!
urban123456789
Post by urban123456789 »
Is there any guide for AviSynth/ffmpeg to make it work
Madoka wrote:Thanks for the new release!
Great work!!
Yay, thanks for confirming these things :)
Wolfgan wrote:Thanks for the release!
Cheers Wolfgan! :)
urban123456789 wrote:Is there any guide for AviSynth/ffmpeg to make it work
There are guides for setting up AviSynth and they should work. Basically you need to set up codecs (I recommended K-Lite) and make sure our version of AviSynth is installed (which is SEt's multithreaded version of 2.6) which is included with the UMS Windows installer.
SuperDre
Post by SuperDre »
The newer version have serious audio sync problems transcoding to PS3..
I don't know why, but I even had to revert back to 4.4.0 (from 6.2.1 to 5.4.0 to 4.4.0) to get a few video's working correctly 6.2.1 and 5.4.0 both had the problem.
I'm always using mencoder, but ffmpeg also seemed to have the same problem.
the video plays, but the audio lags a few seconds behind.
I have practically default settings:
mencoder (settings from 4.4.0, and just updated to 6.2.1 without changing settings, and also back to 4.4.0):
-A/V sync alternative method ON
-remux videos with tsmuxer when possible ON
I've added the mediainfo information of 2 files which seem to have the problem
<edit> it appears the file of the Abyss which I had used as an example is fubar in itself, it was originally out of sync, but the other one really was correct
General
Unique ID                                : 0 (0x0)
Complete name                            : Case Histories S02E01 - Started Early, Took My Dog.720p.hdtv.x264-tla.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 1.07 GiB
Duration                                 : 1h 27mn
Overall bit rate                         : 1 760 Kbps
Encoded date                             : UTC 2010-02-22 21:41:29
Writing application                      : no_variable_data
Writing library                          : no_variable_data
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 5 frames
Muxing mode                              : Header stripping
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 1h 27mn
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Writing library                          : x264 core 132 r2310 76a5c3a
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : A_AAC
Duration                                 : 1h 27mn
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Frame rate                               : 46.875 fps (1024 spf)
Compression mode                         : Lossy
Default                                  : Yes
Forced                                   : No
unouno
Post by unouno »
I'm very thankful to you work. In my experience this is the best server .
thank you.
turbo78
Post by turbo78 »
I have a problem.
When I start UMS a window pop up that there is an upgrade but I have no permissions to change the install folder.
There is a red X on top right of the window but I can not even close that window.
I have to kill the UMS process in Task Manager.
When I download the new version it installs without any problem.
What is wrong here?
Supermanfan77
Post by Supermanfan77 »
turbo78 wrote:I have a problem.
What is wrong here?
You must be running UMS with administration rights in order for that feature to work.
