Having trouble making tsMuxer default engine
Hi, I've been using UMS for a few years now and love it, Thank You! Just recently i studied up a bit more on it and realized I wanted to set up tsMuxer as default so there would be no/little transcoding. I do have a wired gigabit network and am receiving and estimated network speed of 256mb to the PS3.
My computer specs:
CPU: Amd A6 3.6 dual core
Memory: 6gb DDR3 SD ram
I'm running UMS 2.5.2.2
So here' s the main issue I'm having. For transcoding order, I put tsMuxer as 1st and mencoder 2nd. When I start a MKV movie, I immediately get "This content cannot be played. (800288E1)" , it doesn't start at all. The weird thing is, if i go to the #--TRANSCODE--# folder and choose the Movie with [tsMuxeR]{Audio: DTS/English (3/2+1)}* it plays with no problems. I'm no expert, so I'm helping someone could shed some light to get the right settings.
btw, i do have disable subtitles, I'm aware tsMuxer doesn't like them. I zipped a log file recreating the failed streaming.
Here's the part where it fails:
INFO 2013-03-30 09:00:31.292 [New I/O server worker #1-2] Starting transcode/remux of The Hobbit 3Dou.mkv
DEBUG 2013-03-30 09:00:31.307 [New I/O server worker #1-2] Creating pipe \\.\pipe\1364652031307ffmpegvideo
DEBUG 2013-03-30 09:00:31.323 [New I/O server worker #1-2] Creating pipe \\.\pipe\1364652031307videoout
DEBUG 2013-03-30 09:00:31.323 [Thread-109] Waiting for pipe connection \\.\pipe\1364652031307ffmpegvideo
DEBUG 2013-03-30 09:00:31.323 [Thread-110] Waiting for pipe connection \\.\pipe\1364652031307videoout
DEBUG 2013-03-30 09:00:31.323 [New I/O server worker #1-2] Creating pipe \\.\pipe\1364652031323ffmpegaudio01
DEBUG 2013-03-30 09:00:31.323 [New I/O server worker #1-2] Creating pipe \\.\pipe\1364652031323audioout
DEBUG 2013-03-30 09:00:31.323 [Thread-113] Waiting for pipe connection \\.\pipe\1364652031323ffmpegaudio01
DEBUG 2013-03-30 09:00:31.323 [Thread-114] Waiting for pipe connection \\.\pipe\1364652031323audioout
DEBUG 2013-03-30 09:00:31.323 [New I/O server worker #1-2] Creating pipe \\.\pipe\1364652031323tsmuxerout.ts
DEBUG 2013-03-30 09:00:31.323 [Thread-116] Waiting for pipe connection \\.\pipe\1364652031323tsmuxerout.ts
DEBUG 2013-03-30 09:00:31.448 [mencoder.exe-24] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "F:\Movies\The Hobbit 3Dou.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o \\.\pipe\1364652031307ffmpegvideo
DEBUG 2013-03-30 09:00:31.510 [mencoder.exe-24] Attaching thread: mencoder.exe-24
DEBUG 2013-03-30 09:00:31.573 [mencoder.exe-25] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "F:\Movies\The Hobbit 3Dou.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -channels 2 -ovc copy -of rawaudio -mc 0.1 -noskip -oac copy -quiet -quiet -quiet -quiet -srate 48000 -o \\.\pipe\1364652031323ffmpegaudio01
DEBUG 2013-03-30 09:00:31.573 [mencoder.exe-25] Attaching thread: mencoder.exe-25
DEBUG 2013-03-30 09:00:31.692 [Thread-113] Result of \\.\pipe\1364652031323ffmpegaudio01 : true
DEBUG 2013-03-30 09:00:31.698 [tsMuxeR.exe-26] Starting "C:\Program Files (x86)\Universal Media Server\win32\tsMuxeR.exe" C:\Users\Jose\AppData\Local\Temp\universalmediaserver\pms-tsmuxer.meta \\.\pipe\1364652031323tsmuxerout.ts
DEBUG 2013-03-30 09:00:31.762 [tsMuxeR.exe-26] Reading pipe: \\.\pipe\1364652031323tsmuxerout.ts
DEBUG 2013-03-30 09:00:31.889 [tsMuxeR.exe-26] Attaching thread: tsMuxeR.exe-26
DEBUG 2013-03-30 09:00:32.007 [Thread-109] Result of \\.\pipe\1364652031307ffmpegvideo : true
INFO 2013-03-30 09:00:32.184 [StartPlaying Event] Started playing The Hobbit 3Dou.mkv on your PlayStation 3
DEBUG 2013-03-30 09:00:32.185 [StartPlaying Event] The full filename of which is: F:\Movies\The Hobbit 3Dou.mkv and the address of the renderer is: 192.168.1.69
DEBUG 2013-03-30 09:00:32.213 [Thread-127] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
DEBUG 2013-03-30 09:00:32.416 [Thread-114] Forced reconnection of \\.\pipe\1364652031323audioout with result : true
DEBUG 2013-03-30 09:00:32.416 [Thread-110] Forced reconnection of \\.\pipe\1364652031307videoout with result : true
DEBUG 2013-03-30 09:00:32.416 [Thread-114] Result of \\.\pipe\1364652031323audioout : true
DEBUG 2013-03-30 09:00:32.416 [Thread-110] Result of \\.\pipe\1364652031307videoout : true
DEBUG 2013-03-30 09:00:32.437 [Thread-127] 100.0% complete
DEBUG 2013-03-30 09:00:32.437 [Thread-116] Result of \\.\pipe\1364652031323tsmuxerout.ts : true
DEBUG 2013-03-30 09:00:32.655 [Thread-127] 100.0% complete
DEBUG 2013-03-30 09:00:32.781 [Thread-127] Decoding H264 stream (track 1): Profile: [email protected] Resolution: 16:192i Frame rate: not found
DEBUG 2013-03-30 09:00:32.781 [Thread-127] Change H264 level from 3.1 to 4.1
DEBUG 2013-03-30 09:00:32.781 [Thread-127] H.264 stream does not contain fps field. Muxing fps=25
DEBUG 2013-03-30 09:00:32.874 [Thread-127] 100.0% complete
DEBUG 2013-03-30 09:00:33.035 [Thread-127] Decoding H264 stream (track 1): Profile: [email protected] Resolution: 16:12p Frame rate: 2.72009
DEBUG 2013-03-30 09:00:33.035 [Thread-127] Change H264 level from 16.9 to 4.1
DEBUG 2013-03-30 09:00:33.101 [Thread-127] 100.0% complete
DEBUG 2013-03-30 09:00:33.129 [Thread-124] Bad SEI detected. SEI too short
DEBUG 2013-03-30 09:00:33.139 [Thread-114] Disconnected pipe: \\.\pipe\1364652031323audioout
DEBUG 2013-03-30 09:00:33.140 [Thread-124] Bitstream exception Unknown exception. It does not have to be! Plase contact the application support team for more information.
DEBUG 2013-03-30 09:00:33.142 [Thread-110] Disconnected pipe: \\.\pipe\1364652031307videoout
INFO 2013-03-30 09:00:33.150 [tsMuxeR.exe-26] Process C:\Program Files (x86)\Universal Media Server\win32\tsMuxeR.exe has a return code of -3! Maybe an error occurred... check the log file
DEBUG 2013-03-30 09:00:33.151 [tsMuxeR.exe-26] Stopping process: mencoder.exe-24
DEBUG 2013-03-30 09:00:33.152 [Thread-109] Error: null
DEBUG 2013-03-30 09:00:33.152 [tsMuxeR.exe-26] Stopping process: mencoder.exe-25
DEBUG 2013-03-30 09:00:33.153 [Thread-112] Error :null
DEBUG 2013-03-30 09:00:33.153 [Thread-108] Error :null
DEBUG 2013-03-30 09:00:33.154 [Thread-113] Error: null
DEBUG 2013-03-30 09:00:34.689 [Buffered IO End Checker] Stopping process: tsMuxeR.exe-26
INFO 2013-03-30 09:00:37.206 [StopPlaying Event] Stopped playing The Hobbit 3Dou.mkv on your PlayStation 3
DEBUG 2013-03-30 09:00:37.206 [StopPlaying Event] The full filename of which is: F:\Movies\The Hobbit 3Dou.mkv and the address of the renderer is: 192.168.1.69
DEBUG 2013-03-30 09:02:07.508 [AWT-EventQueue-0] checking dbgpack property in UMS.conf
DEBUG 2013-03-30 09:02:07.508 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2013-03-30 09:02:07.508 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2013-03-30 09:02:07.508 [AWT-EventQueue-0] adding C:\Users\Jose\AppData\Local\Temp\debug.log
DEBUG 2013-03-30 09:02:12.285 [AWT-EventQueue-0] packing C:\ProgramData\UMS\WEB.conf
DEBUG 2013-03-30 09:02:12.285 [AWT-EventQueue-0] packing C:\ProgramData\UMS\UMS.conf
DEBUG 2013-03-30 09:02:12.285 [AWT-EventQueue-0] packing C:\Users\Jose\AppData\Local\Temp\debug.log
My computer specs:
- (30.06 KiB) Downloaded 494 times
