[Solved] UMS just stopped working and I am at a loss.....
Klaymoor
Post by Klaymoor »
I created and attached my log file as stated in the How To Ask for Support sticky.
My set up is:
-All-in-one PC, Windows 10 x64
-UMS v.6.3.0 Build Date 2016-05-07
-Linksys E1200 Wireless Router
-PS3 Wired Connection
-PS4 Wireless Connection
I hope this is enough info but just let me know if you need anything else.
My problem is that UMS just stopped working. Literally, last night we listened to music and watched a few shows on the PS4. Later, the wife & I watched a show on the PS3. No problems, everything worked like it has since I set everything up. Now today, I went to pull up a show for my son and nothing. UMS is gone on both the PS3 & PS4. Their renderer icons are gone from the Status screen. I changed nothing. In an attempt to fix the problem I did update UMS to the newest version. No change.
On a side note, ever since I set everything up on the new All-In-One PC, each one of the user accounts on the PC shows up as an available media server on my PS systems. Even though UMS is gone, these entries continue to show up. So I know the PS machines can see the PC. Additionally, if anyone knows how to remove these from showing up it would be nice.
Anyway, I just want things working again and I am at a loss.
"Please help me Obi-Wan your my only hope!"
Klaymoor_ums_dbg.zip
(26.36 KiB) Downloaded 366 times
Klaymoor
Re: UMS just stopped working and I am at a loss.....
Post by Klaymoor »
OK, I fixed this. About 1/10000 of a second after I posted this message I came across this post.
Java 8u91 breaks UMS
viewtopic.php?f=9&t=7936
I updated Java like 2 weeks ago with no problems. I reverted back to u72 and everything is back to normal. STUPID JAVA!
BTW, Thanks viktor87.
