PS4 issue and setup
firstcolle
PS4 issue and setup
Post by firstcolle »
i found this strange issue (UMS 6.3.2 Java 8)... if the PC and ums are UP from the morning and a use UMS in the evening the first time the PS4 can't find UMS. i have to restart UMS.
apart from that all works fine. is it possible to implement a "skip transcode for codec" ? now i've setted UMS to skip all .mkv files and the PS4 can transcode almoast all H264 but not H265. is possible to disable the transcode only for mkv h264 and not h265?
thanks
CZSK
Re: PS4 issue and setup
Post by CZSK »
firstcolle wrote:Hi,
thanks
That should be possible. Have you tried with this option?
firstcolle
Yes, i type mkv on thet line but h264 as h265 is not transcoded. I wont to skip transcode only forfor h264
Hi firstcolle, we have fixed the bug where the device isn't found in the upcoming version
