older versions of UMS
Since the latest 6.4 download, al lot of movies won't play anymore.
Where can we download the older versions like 6.3 for example
Here http://www.oldfoss.com/Universal-Media-Server.html only a few files can be downloaded, and the older versions for windows are missing
Re: older versions of UMS
hi a friendly advice keep the ones that works the best for you in case something like this happens again or if you need to reinstall for another reasons.
Hi ceasar, if you can post before and after logs we can hopefully see why the files aren't working for you on the new version
