green bar corruption at top of video
SuperDre
Post by SuperDre »
With the current release of UMS I've got a green 'bar' at the top of the video (not all video's, but it seems to happen with 720p), I have no idea what the problem could be. the last version SB71 of PMS doesn't have that problem.. Renderer is PS3 and Windows 7 x64.. having mencoder as default..
Madoka
Re: green bar corruption at top of video
Post by Madoka »
I had that on one of my files. Try checking deinteralce filter. That fixed it for me on that file.
Thanks for reporting the bug, can you please attach the debug.log?
eva01
Post by eva01 »
Also I have the same error with some files
squadjot
Post by squadjot »
It's not a biggie, but with most movies i have some white dots just at the bottom edge, below the movie..
I use vf expand to 16/9
If someone can attach a debug.log I can probably fix it easily, I suspect I know what it is but need to confirm with a debug.log :)
SuperDre
Post by SuperDre »
SubJunk wrote:If someone can attach a debug.log I can probably fix it easily, I suspect I know what it is but need to confirm with a debug.log :)
If I'll have the time 2night I will add it, didn't have time, but in another thread about the same problem there is a debug.log attached..
The only other thread I can see about this bug is here with no debug.log, maybe I'm blind, can you link to it?
SuperDre
Post by SuperDre »
Sorry I still hadn't have the time :(
but the thread with a debug.log is the following: viewtopic.php?f=9&t=92
Hmm looks like I can't find the fix from the debug.log, can someone give me a link to a file that causes the bug?
