Update process
Update process
Under Linux, the update process of UMS is a pain (open UMS, check udpates, open browser, download the last version…). As under Windows ! While under Linux, there are two fine solution : software center for Ubuntu and others, and the PPA (Personal Package Archives).
When UMS will have an update process with PPA and/or in software center ?
Re: Update process
hi on the general settings next to logs there is AN option to verify if there is AN update and next to it there is a box that you can check to automatically look for updates.
