Profile for renderer Samsung 4K (UHD SUHD)
Profile wrote for all Samsung UHD and SUHD since 2014.
Working for (HUXXXX, JUXXXX, JSXXXX, KUXXXX, KSXXXX) and surely futures series
As Samsung recently update their firmware, all these models are capable of the same render (uniform codec package).
This profile is better than (and replace) Samsung-HU7000.conf, Samsung-HU9000.conf and Samsung-JU6400.conf as it allow more render capabilities and UHD streams.
So these 3 files should be deleted if you want to use it with HU7000, HU9000 and JU6400 models.
Others Samsung UHD TV had no conf file yet.
I have not included WEBVTT subtitles format (it was on the JU6400 conf file) as I don't see any specification in all Samsung manual, even for JU6400.
Feel free to add it if you want at your risk.
Any feedback is welcome.
- Icon if needed
- samsung-tv-uhd.png (27.3 KiB) Viewed 28952 times
Re: Profile for renderer Samsung 4K (UHD SUHD)
thx for this file but I have two problems... fist I have dubled subtitles and I can not move by line to go forward or bacword on time scale...
othervise the Picture is good does it support also hdtrue sound
I have try this file on UE55HU8500
also please for instruction where to copy those files in latest UMS and how to setit up then...
best
best
in x264 movies at my TV 8500 time line for fast forward and backword doesnt work it show from 00 ---- 03 sec and thats it but the movie is working as you leaveit...
we have talk a few of us we have that kind of TV's and share info....
best
best
THX !!!
It works flawless with my KS7000 49"
Just Watched the Revenant ... wow stunning !
just one minor problem, Live Subtitles doesn't seem to be working.
I have remove all files from Render map and put inside this file Samsung-UHD.conf
why I can not use timeline to jump forward and bacword it show me full line as the whole movie was already shown???
please for helping me out....
this happening me on Samsung UHD8500TV
but if I use original installed files in renderer map and then play all those files on Panasonic Plasma 5years old it Works like a cham
pleaseee
pleaseee
alesk76 wrote:...
pleaseee
Developers cannot help you without logs.
This does not work for a UN65HU8550 as it will not use this profile for some reason. I select it for the TV and it will change to defaultrenderer.conf. Does it have something to do with the line UpnpDetailsSearch = U[NEA]\d{2}[H-Z][SU]\d{4}.*(Samsung TV)?
Yes, that's the match string.viperxoc wrote:This does not work for a UN65HU8550 as it will not use this profile for some reason. I select it for the TV and it will change to defaultrenderer.conf. Does it have something to do with the line UpnpDetailsSearch = U[NEA]\d{2}[H-Z][SU]\d{4}.*(Samsung TV)?
Dear all,
now I own a Samsung KS7090 (55") and I want to stream 4K UHD videos but it is very stutteringly.
UMS hardware is:
- Intel Core2Quad Q8400 2.66 GHz
- 8 GB RAM
- Gigabit Network
CPU is around 60% and network is around 15% while streaming 4k but it is stuttering.
HD (1080p) is running fine.
Any suggestions which settings I could check to optimize?
UMS hardware is:
- 8 GB RAM
- Gigabit Network
