How to use UMS
stuartgb100
How to use UMS
Post by stuartgb100 »
I've just come across UMS, downloaded and installed the latest release.
When UMS starts it detects my Samsung Tv.
Is there an instruction guide for new users ?
I'm at a loss how to (for example) play a video from my laptop on the Tv.
Many thanks.
squadjot
Re: How to use UMS
Post by squadjot »
Which model is the Samsung TV?
Usually you find it through the "Smart hub", see if you got something called "My content". The UMS Server should be displayed there.
stuartgb100
Re: How to use UMS
Hi squadjot,
Thanks for the reply.
no, nothing named My Content
Anything else to look for /
The Samsung is UE40D 6530 WK
Thanks.
squadjot
Re: How to use UMS
Post by squadjot »
I guess this is close enough http://www.samsung.com/uk/support/model/UE40D6530WKXXU
The manual - from page 208 and on it mentions something about AllShare and DLNA. Does that help?
Sandman
Re: How to use UMS
Post by Sandman »
On my Samsung, once I start UMS, on the TV I hit the 'Source' button on the remote and UMS is one of the choices at the top. This takes you into the file path that you specified in UMS and you can browse with the control.
