Media Server Error
Media Server Error
I'm using V3 alpha and it's been fine, today I'm getting;
Media Server Error:
An HTTP error (500) has occurred
Media Server Error:
- Optimus_prime
Re: Media Server Error
I've never seen that one myself, whats the log look like?
Will post log later if necessary....have tried 2.6.2 and get a different error....as the files are stored on an external hard drive (formatted ntfs) UMS runs on a linux machine.....so I'm currently checking the HD via my windows machine to see if it finds and fixes any errors, could be the ExHD is failing.Optimus_prime wrote:I've never seen that one myself, whats the log look like?
Chkdsk seems to have fixed errors and its back up, however, will keep my eye on it, but the debug log appears to be showing a large # of font errors. Will run same film later and add debug log file.
The error occurred again so I switched HD's and copied a few movies to a 1Tb drive.....same error.....have attached dbug for reference.
- http error ums_dbg.zip
- (5.38 KiB) Downloaded 535 times
- Optimus_prime
Could you post a debug log on trace for 2.6.2 playing the same file please geaves. I would like to compare the two versions
Log attached, but different error.Optimus_prime wrote:Could you post a debug log on trace for 2.6.2 playing the same file please geaves. I would like to compare the two versions
- 2.6.2 trace ums_dbg.zip
- (9.11 KiB) Downloaded 511 times
Attached another log from 2.6.2 but this is with the film from my PC HD, same error.
- 2.6.2 trace PC HD ums_dbg.zip
- (14 KiB) Downloaded 524 times
- Optimus_prime
Sorry mate is this the only file this is failing for. What i can see is that it tries ffmpeg, mencoder and reports the External input steam instance is null.... quite a few times. I'll do a bit more digging and see what i can see.
Edit: what type of linux are you using, when was the last time you updated ffmpeg?
Ok....further to this I have installed UMS on my windows machineOptimus_prime wrote:Sorry mate is this the only file this is failing for. What i can see is that it tries ffmpeg, mencoder and reports the External input steam instance is null.... quite a few times. I'll do a bit more digging and see what i can see.
BTW....I have set the default player on each to VLC rather than Mencoder, the error applies to all films, but the film will play with no issues in VLC as a standalone player so I know the film/s are OK....
Linux is Ubuntu Precise.....and I've just update ffmpeg.....so retried UMS still the same http error.....
