Willing to create Pioneer BDP-450 conf
Tschacko
Post by Tschacko »
Hey guys,
I'm trying to find the best solution to stream movies to my Pioneer BDP-450 from my PC.
So far the best solution is to use the PS3 Media Server...although there is Universal Media Server. This doesn't run. It seems to die in a loop and only when I close UMS the Pio comes back to life.
Why is PS3 Media Server running with the unknown renderer and UMS not ?
I'm trying to find a solution for streaming mkvs with Dolby True HD sound in it. Do you have any suggestions ?
I thought the Oppo 93 conf might be a good solution to start but not any of the files I've trying to run (mkv,avis), run.
The pioneer supports many formats found here:
http://www.pioneer.eu/uk/products/42/84 ... specs.html
I'm willing to help all the pioneer guys but gimme a good starting point !
Thanks Tschacko
Tschacko
Re: Willing to create Pioneer BDP-450 conf
Post by Tschacko »
Short update...I tried the Oppo config on the PS3 Media server...there it works.
With the BDP-450 I cant get the UMS to run....any ideas ?
Optimus_prime
Post by Optimus_prime »
Thanks for posting Tschacko, Please post your .conf file so we can take a look at it. Also post a debug log set on trace as per these instructions viewtopic.php?f=9&t=556 making sure you click the restart server so it can attempt to detect you BDP-450
Tschacko
Post by Tschacko »
I always even close the universal media server if I do a change
So the PS3 Media Server runs with the unkown renderer and the Oppo-93 conf with no problems. The UMS doens't work - even with the unkown renderer. It have the feeling that it also gets stuck browsing the movie library showing that he tries to serve the movie. This is not wrong but it takes him some time to stop and to enable scrolling back on the BDP-450. If I click on a movie nothing happens. The BDP freezes and only when I close it it gets back to work.
The config is the Oppo93 conf that works on the PS3 media server...the trace log I will post later...when I'm back home
# Universal Media Server renderer profile for OPPO BDP-93
# Refer to PS3.conf for help
RendererName=OPPO BDP-93
UserAgentSearch=OPPO PLAYER
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeVideo=MPEGAC3
TranscodeAudio=PCM
DefaultVBVBufSize=true
MuxH264ToMpegTS=true
MuxDTSToMpeg=true
WrapDTSIntoPCM=false
MuxLPCMToMpeg=false
MaxVideoBitrateMbps=0
MaxVideoWidth=0
MaxVideoHeight=0
H264Level41Limited=false
TranscodeExtensions=iso,vob
StreamExtensions= gif,jpg,png,aac,flac,m4a,mp3,pcm,wav,wma,avi,mkv,mp4,m2ts,ts,wmv
Tschacko
Post by Tschacko »
Here comes the trace output...so the server just hangs when I play any demo file
Debug
(264.4 KiB) Downloaded 475 times
Optimus_prime
could you try this config, not much of a change but it's the only difference between the two media servers
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeAudio=LPCM
MuxDTSToMpeg=true
MuxLPCMToMpeg=false
MaxVideoWidth=0
MaxVideoHeight=0
Tschacko
Post by Tschacko »
I tried it...doesn't work. I can scroll through the movies...but playing just doens't start and hangs up the device....here another trace log ! Any suggestions Optimus ?
ums_dbg_1.zip
(238.41 KiB) Downloaded 479 times
